Problem please help
Old Jul 5, 2010 | 11:48 PM
Xentech997's Avatar
Xentech997 is infamous around these parts
Problem please help
Hi,
i bought my 04 Cayenne turbo about a month ago with 40K miles on it . The steering wheel is shaking very bad and i couldn't find out what is the problem. any thought please help. thank you
Old Jul 6, 2010 | 01:23 AM
Xentech997's Avatar
any thought will be great helpful. thank you
Old Jul 6, 2010 | 05:14 AM
thor7000's Avatar
thor7000 is infamous around these parts
sounds like you have a bad tire!! That would be the first thing I would have checked, any local tire shop can check that out for you.
Good luck!
Old Jul 6, 2010 | 05:17 AM
Fantasma's Avatar
Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !
wheel bearing... bad tires... bolts on wheel not tight... etc
Old Jul 6, 2010 | 04:53 PM
Xentech997's Avatar
Hi,
i already did the wheel balance , aligement but still have the same problem...
Old Jul 7, 2010 | 01:37 PM
xTapouTx's Avatar
xTapouTx is infamous around these parts
If you jack the car up do you have camber caster play? Movement in the wheel that's not suppose to be there is what I'm asking.
Any issues with the air suspension? Can you raise and lower the car just fine?
You said you had a wheel balance but did they rotate?
Was it two different shops that did the balance and then the alignment?
Old Jul 7, 2010 | 04:13 PM
Xentech997's Avatar
Hi,
yes, they did rotate the wheels. i just check with the tech today and they told me that it might be the drive shaft problem. is it true ?
Old Jul 7, 2010 | 06:40 PM
joe731's Avatar
joe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to behold
There are plenty of early Cayennes out there that have had the drive shaft replaced. Seems like a real defect without a factory recall.
My 2004 Cayenne Turbo had the driveshaft replaced by the previous owner at fewer than 40k miles
Old Jul 10, 2010 | 06:23 AM
BARFLY 228's Avatar
BARFLY 228 is infamous around these parts
Need more info does it idle rough with the steering wheel shake is so probably ignition pencil coils!!!
Old Jul 10, 2010 | 07:58 AM
the head's Avatar
the head is a jewel in the roughthe head is a jewel in the roughthe head is a jewel in the roughthe head is a jewel in the rough
Does it do it at any particular speed range or all the time?
PV=nRT.
Sep 9, 2022 06:06 PM
cockneymike
Oct 22, 2015 06:00 PM
vogz
Sep 19, 2015 01:02 PM
nal991
Sep 11, 2015 09:05 AM
flewis763
Sep 10, 2015 01:08 PM
