How do you remove the whole ashtray compartment?
Old Nov 1, 2010 | 11:38 AM
Fkim011's Avatar
Fkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant future
I have a 2010 GTS and I have a coin stuck behind the whole ashtray compartment, not allowing me to close the ashtray altogether. I am not talking about the removing the tray in the ashtray but the whole unit itself. I see no clips around the outside perimeters and was wondering if anyonr here can help!
Frank
Old Nov 1, 2010 | 08:09 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
Try a search, this has been discussed several times.
Old Nov 1, 2010 | 10:04 PM
GQpro's Avatar
GQpro is infamous around these parts
I have the same problem too. I think I have many coins inside of it. But I am luckly I still can close it.
Old Nov 1, 2010 | 10:42 PM
Fkim011's Avatar
Found some threads, but those are threads regarding pre touch screen pcm Cayennes. I took the trim off, and I found no spring clips.
Anyone try to remove the ashtrays on the newer Cayennes with the touchscreen pcm?
Old Nov 2, 2010 | 07:58 PM
2003-2010 all are the same, CDR23, CDR30, PCM2.0, PCM 2.1, or PCM3.0, when it comes to removing the ashtray. The 2 screws are accessible once the air condition head is removed.
Edit: https://www.6speedonline.com/forums/...y-my-05-s.html
Old Nov 3, 2010 | 08:41 AM
Fkim011's Avatar
Thanks for the info.
When I take the horseshoe surround off, I see a metal clip where the plastic trim was held in and just inside that there is a metal clip.
Is that the metal flip you are talking about?
Old Nov 3, 2010 | 07:13 PM
No I'm referring ot eh clips that hold the A/C control unit in the dash. They are hard to see(one on each side), and you need to have the car in drive with the e-brake set to remove it all the way.
Old Mar 21, 2012 | 12:43 AM
pcst's Avatar
pcst is a jewel in the roughpcst is a jewel in the roughpcst is a jewel in the roughpcst is a jewel in the rough
sorry to bring up this old thread, but the same thing happened to me unfortunately,, managed to drop a quarter behind the tray and the sliding tray got stuck when I closed it, once I tried to open it, it won't open, had to tap the side to pop it out.
I wonder if I can park my Cayenne on uphill and tap the side to see whether the coin would slide out or not, no need to save a quarter but just want it to be outta the way... anyone got a picture of the tray structure?
Old Mar 22, 2012 | 07:16 PM
kas930's Avatar
kas930 is infamous around these parts
Maybe this will help you to figure out where the clips are. Mine is from an '05 CTT so I'm not sure if yours would be different. Good luck!
Old Mar 22, 2012 | 07:37 PM
kas930's Avatar
I felt as if the ashtray was a waste of space, so I bought a second one off of ebay and made a custom pocket out of it. It's good for throwing my cell phone in, etc.
Old Apr 11, 2013 | 11:20 PM
stormy69's Avatar
stormy69 is infamous around these parts
thanks for the pics, mine had a dime in it
Old May 14, 2015 | 08:17 AM
Zuffenhausen955's Avatar
Zuffenhausen955 is infamous around these partsZuffenhausen955 is infamous around these parts
Cigarette Socket No Longer Pops-up....
I need to do this too. Anybody know how to re-assemble the ashtray insert? I have no idea how the spring(center) is oriented:
Old May 14, 2015 | 09:18 AM
TSAF NKUF's Avatar
TSAF NKUF is infamous around these parts
This is why all change goes in the center console. Reminds me i need to dump it cause every time i take a corner is sounds like a coin bank sloshing around.
pshep138
Oct 6, 2015 11:58 AM
MrMiggy
Sep 14, 2015 02:18 PM
kensworth
Cayenne 955/957
Sep 9, 2015 05:45 AM
AM v12v
Sep 7, 2015 02:17 PM
Wildcat1212
Sep 7, 2015 11:31 AM
