PROBLEM with my CS
Old Nov 5, 2005 | 09:44 PM
Jon Tab's Avatar
Jon Tab is infamous around these parts
PROBLEM with my CS
Has anyone had the problem of the car shaking back and forth a little and jerking due to a leak or something in the fabspeed bypass pipes or maybe because of the exhaust system? Is there a significant loss of backpressure or is it something else because when I am in 4th or 5th gear and I tap the gas pedal, the power delivery is interrupted by jerking. This problem has been bothering me and I just dont know exactly what to do. Thanks in advance for all your input.
Old Nov 7, 2005 | 09:44 AM
mudman2's Avatar
mudman2 is infamous around these parts
Nothing to do with the exhaust going by your description. It sounds like your eGas or DME is not working right. Make sure the dealer has your car up to date with all the service actions.
Old Nov 7, 2005 | 12:04 PM
jamy85's Avatar
Boobie Stars
jamy85 is infamous around these parts
Re: PROBLEM with my CS
I have heard that before. The guy fixed the problem by removing the fabspeed bypass pipes. It was on a turbo though.
Old Nov 7, 2005 | 06:55 PM
alex911s's Avatar
alex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond repute
Jon, Jamy,
How about the Sebring exhaust? is that made for cayenne specs?
Dont know anyone who has the issue with bypass.
I feel bad, Jon bought the bypass from me but I agree with Mudman because I didnt have the issue with my S. Let me know
Jon, maybe we can get Joe from Fabspeed help us...
Alex
Old Nov 7, 2005 | 08:13 PM
jamy85's Avatar
Boobie Stars
Originally posted by alex911s
Jon, Jamy,
Alex
Never heard about the serbring exhaust. I agree a lot of people didnt have any issues with the fabspeed bypass pipes. However I recall a while back that someone on rennlist lost back pressure when he installed the fabspeed bypass pipes on his turbo. He said he removed the bypass pipes and it was "fine" it was on a turbo and not an S. Jon you could be experiencing the normal lag on all cayennes! are you sure the lag happened as soon as you installed your bypass pipes?
Old Nov 7, 2005 | 09:20 PM
Jon Tab's Avatar
I'm pretty sure its not the Sebring exhaust because I have had that over a year with no problems:its Sebring tips with custom JKL mufflers. As for the bypass pipes, they were fine for the first month but all of a sudden I had this problem. Could it be that I was slightly hitting speed bumbs too hard and the pipes got loose? Because when I am standing outside the car, I also smell the exhaust gases from the right side of my car and I dont think the smell was that strong before. I took it to Porsche service and they said that they checked everything besides the exhaust and since I did not have a check engine light in the first place, that this problem was not there responsibility. Hopefully I can get this issue resolved.
Old Nov 7, 2005 | 11:32 PM
jamy85's Avatar
Boobie Stars
Let the shop who installed your bypass pipes have a look at your car.
Old Nov 9, 2005 | 01:56 AM
Jon Tab's Avatar
Ok. Thanks Jamy and Alex for your concern.
Old Nov 9, 2005 | 10:10 AM
alex911s's Avatar
Jon,
Check your bypass pipes for cracks as well, we have some people on rennlist that have cracks on theirs, but none of them reported jerking though.
Old Nov 9, 2005 | 11:21 AM
JoeG's Avatar
JoeG is infamous around these parts
I had the fabspeed bypass pipes on my 04 turbo. Experienced similar problems as above. car fel like it lost power and also had a herky jerky feel to it! pulled off the by pass pipes to learn one was cracked! Not sure if that was what caused the problem but i could get no help from fabspeed when trying to resolve the situation. Ended up throwing them in the garbage. I put the stock cats back on which resolved the problem. A few months later i upgraded ecu and added high flow cats. i never looked back!
Joe
Old Nov 9, 2005 | 03:47 PM
CayenneTurbo77's Avatar
CayenneTurbo77 has a spectacular aura aboutCayenneTurbo77 has a spectacular aura about
Joe G, did you replace the main cats with the hi flow cats also or just the secondary cats where the bypass pipes had been? if so what company makes them and where did you get them?
Old Nov 9, 2005 | 03:52 PM
JoeG's Avatar
my understanding is nobody makes primary cat replacements. After all the fabspeed BS I ended up putting on Cargraphic high flow secondary cats. Shortly after I did their ECU as well. Give Erik at cargraphic a call and tell him Joe G sent you
Joe
adnanm3
Oct 25, 2016 08:38 AM
cockneymike
Oct 22, 2015 06:00 PM
Zero911
Sep 24, 2015 06:33 PM
vogz
Sep 19, 2015 01:02 PM
