Found the TQ Dyno From My CTT
Hey Guys,
Finally got the Torque graph for my FVD Level 2 Cayenne Turbo (I can't find the HP one)! Both sheets went missing awhile back (the HP still is)! Well I thought you guys would get a kick out of the sheet
. Remember this truck only has FVD Programing, BMC Filters, FVD 2ndary Cat Bypass, FVD Export Muffler!
This dyno was on Champion MS's 4 wheel dyno!
This is a before and after TORQUE Graph! The "Power" curve was with BMC Filters, Cat Bypass, and Muffler. The "Torque" curve was with the addition of the FVD Level 2 ECU!
Not bad huh
Pretty freak peak number
Guess I got one of the strong Cayennes and Strong Programs
If only the stock turbos could flow more and hold the torque to redline! Geeez I want new turbos BAD!
Regards,
Evan
. Remember this truck only has FVD Programing, BMC Filters, FVD 2ndary Cat Bypass, FVD Export Muffler! This dyno was on Champion MS's 4 wheel dyno!
Not bad huh
If only the stock turbos could flow more and hold the torque to redline! Geeez I want new turbos BAD!Regards,
Evan
Regards,
Evan
Regards,
Evan
Originally Posted by mono2100
man I feel you...if only my exhaust would stay on my brackets keep breaking..and need to have them welded its driving me nuts
Evan
supersprint...with fabspeed bypass
Best Regards,
Evan
Sorry to hear of your troubles! If you can sell the Supersprint I will hook you up with an FVD muffler that has a 3 year warranty against incidents like that...
Best Regards,
Evan
Best Regards,
Evan
Hi Mike,
Unfortunatly at redline the turbos are maxed out already (with stock boost). Any tuner's graph you look at drops to stock power around redline... They will not make more power up top unfortunatly... Doesn't matter what boost you run...
Regards,
Evan
PS- Here is an example off Evo's site, you can see just as my graph the torque drops to stock up top...
Regards,
Evan
Originally Posted by mikejones997
Not Mine,but I See What You Are Taking About. I Will Post Up My Graph When I Get Home
Evan
