Cayenne problems
Old Apr 1, 2004 | 02:47 PM
vipertestarossa's Avatar
vipertestarossa is a jewel in the roughvipertestarossa is a jewel in the roughvipertestarossa is a jewel in the rough
Cayenne problems
Has anyone had the same problems?
Very hard to close rear hatch and rear window, when cold trans feels like its holding back and very stubborn remote key fob
It is an '04 with 1000 miles, bought new
Old Apr 1, 2004 | 02:51 PM
DEETZ's Avatar
GO 6SPEED!
DEETZ is infamous around these parts
no problem with mine, but there is a rattle noise from the glass window when I close it
Old Apr 1, 2004 | 03:52 PM
ffr996's Avatar
Senior Member
ffr996 is infamous around these parts
Never had a problem with mine either, but i did notice that you are not able to open the rear window unless the tailgate is closed
Old Apr 1, 2004 | 05:17 PM
ESK's Avatar
ESK
Hick from NH
ESK is infamous around these parts
I've found that you have to pull the glass down fast - not slam it - inorder to get it to close properly. If you slam it down, it does not stay locked and is wobbly. I've had no problems with the automatic tailgate.
Old Apr 1, 2004 | 05:59 PM
mike's Avatar
mike is infamous around these parts
All of you need to get the hatch mechanism adjusted by the dealer, you describe very common issues, fixed in about 20 minutes.
Old Apr 1, 2004 | 06:33 PM
Thanx for the replies
Old Apr 1, 2004 | 07:52 PM
DEETZ's Avatar
GO 6SPEED!
what about the rattle noise guys? is there anyway I can fix it?
Old Apr 1, 2004 | 10:13 PM
jamy85's Avatar
Boobie Stars
jamy85 is infamous around these parts
You have to close to rear hatch hard inorder for it to close properly.... well thats what i do!!!
Old Apr 1, 2004 | 11:43 PM
DEETZ's Avatar
GO 6SPEED!
I did that and it didn't help, any other solutions? I'm gonna get the dealer to check it out and also there is something wrong with my front two doors
Old Apr 2, 2004 | 05:14 AM
mike's Avatar
Deetz the rattle or closing problems etc are caused by the incorrect adjustment of the latch.
The motor for the wiper is in the tailgate so the latch is also part of the motor mechanism.
Its very easy to adjust, it will stop the rattle and make it easier to close, I had it last June and I did not even have to leave the car to have the adjustment done.
Old Apr 2, 2004 | 08:25 AM
dmerc's Avatar
dmerc is infamous around these parts
Viper....I have the same things with the cold tranny and remots key. Sometimes both are very stubborn!! Im taking my Cayenne S to the dealership next week for an evaluation.
Old Apr 2, 2004 | 08:52 AM
mike's Avatar
The cold start issue you may be refering to could be the transmission program on cold start which starts and holds first gear and other low gears in an attempt to get the cats up to temp to reduce emissions.
If this is the case its normal.
The remote takes a bit of getting used to, its very short range and takes a bit of getting used to.
Basically the range is about 10 ft, some a bit more some a bit less based on the approach angle.
You need to press and hold to unlock sometimes especially if you just locked it. Some sort of timeout has to occur before the open command is accepted (about 2 secs).
Old Apr 2, 2004 | 09:05 AM
DEETZ's Avatar
GO 6SPEED!
thanks guys!!! I will go to my dealer next tuesday to get it fixed, and also my front two doors problem
Old Apr 4, 2004 | 11:24 AM
hyroller's Avatar
hyroller is infamous around these parts
Viper, Same problem with my back glass. Had it ajusted by dealer, now to lock it I close gently to first lock detent then slight extra push to lock. B4 had to slam to lock it,only locked about half the time. Get yours adjusted.
PV=nRT.
Sep 9, 2022 06:06 PM
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
dgreen78
Feb 29, 2016 11:28 PM
manfred@loma_wheels
Sep 2, 2015 11:22 AM
