Is this normal?
Old Jun 26, 2007 | 12:19 AM
blackctsv's Avatar
blackctsv is infamous around these parts
Is this normal?
I have noticed when braking or decelerating on motor that I can feel the car jerk a bit on downshifts when the speed gets low coming to a stop. It isn't very hard but can be noticed from drivers position and as a passenger. Is this normal or should I take it in to have it looked at?
Old Jun 26, 2007 | 08:07 AM
codey's Avatar
codey is infamous around these parts
I have the SAME exact problem. The car will jerk when the brake is pressed and the car downshifts.
funny..we both have an '04 Cayenne S
Old Jun 26, 2007 | 12:44 PM
MeanMachine's Avatar
Maybe its an 04 model problem, but I think you should check or change the oil in the motor or the car is in need of a basic service airfilters and so on. That should do the trick, Please notify the dealership that the car jerks when you slow down.
Old Jun 26, 2007 | 02:55 PM
Sleepy996's Avatar
Sleepy996 is a jewel in the roughSleepy996 is a jewel in the roughSleepy996 is a jewel in the roughSleepy996 is a jewel in the rough
I have the same problem with my 2004CS and occurs on cold starts, I am no mechanic but I have the feeling it's something more serious then air filters and a oil change however who knows !
Old Jun 26, 2007 | 05:53 PM
blackctsv's Avatar
Hmm seems to be something pretty common. I took it out again and found that the jerk is from the revs dropping too low for the gear before it kicks down. Much like a manual car does if you leave it in a high gear and do not downshift/clutch when slowing down.
I'm thinking it is a software/computer setting that needs to be updated.
Old Jun 26, 2007 | 07:03 PM
alex911s's Avatar
alex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond repute
have the coils checked, it's under warranty..and an issue
Old Jun 26, 2007 | 08:21 PM
codey's Avatar
I had the coils changed a few months back because the car stuttered on acceleration in low gear when the rpms were mid to low range. (car remained in automatic). The coils did not change the problem when the car downshifts.
Old Jun 26, 2007 | 09:04 PM
blackctsv's Avatar
I made an appointment today to have mine checked out. I think I'm going to have my coils checked too because my idle seems to be low.
Anyone know if there is an actual TSB on this?
Old Dec 19, 2007 | 12:28 PM
wirx's Avatar
wirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud ofwirx has much to be proud of
same problem here, has anybody find answer?
2004 Cayenne S and when cold, idling isn't very good and rpm-s are low
edit: Seems that it is Coil's problem
http://forums.rennlist.com/rennforums/showthread.php?t=254673&highlight=idle
Old Apr 12, 2008 | 11:56 AM
baseballfanz's Avatar
baseballfanz is infamous around these parts
Not sure if this is the same but my wife's 08 Cayenne (v6)
When coming to a stop at a light or stop sign, the RPM will jump from 500 to about 1000RPM sometime a little higher, it will do this a few time and you can feel like it's trying to launch itself. Took it to the dealer and off course they say they can't duplicate the problem. Is this a normal thing? That's what they say but I don't think it's normal for an engine to "rev" itself like that.
Old Apr 12, 2008 | 12:30 PM
canberk's Avatar
canberk is infamous around these parts
Guys, how serious is that jerking problem, is it slightly jerking or obviously jerking.Because if you are talking about that slight little jerk, that's normal, it has a 4.5liters engine with 8 cylinders and it is downshifting to help breaking, what do you expect? Try putting the car in manual mode and when you are on 3rd gear, try breaking and stopping, it is much harder to stop on 3rd gear compared to downshifting...
Old Apr 12, 2008 | 01:38 PM
Subbie's Avatar
Subbie is infamous around these parts
04-06 have shifting issues. I go rid of my 04 CTT for this reason, felt like the tranie was about to blow up. Also at about 60k miles the coils had to be replaced. FYI the 08 CTT shifts as smooth as can be.
Old Apr 12, 2008 | 10:13 PM
p0rsch3's Avatar
p0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond repute
no issues with my '04, it's been smooth as silk. Of course I only have 17k and change on it... so we'll see.
Old Mar 27, 2023 | 12:52 PM
GT3 Chuck's Avatar
Administrator
15 yr old thread
nhirsch
Cayenne 958
69
Apr 22, 2013 04:14 PM
0zzy997
Dec 28, 2012 01:27 PM
Dbezerra
Cayenne 958
Jun 28, 2011 08:34 PM
Kafka997
Sep 17, 2010 02:28 PM
ElusiveC4
Dec 10, 2007 08:24 PM
