2014 to 2015+ Cayenne Backup Camera Upgrade
Old Jun 13, 2018 | 03:15 PM
RickDC's Avatar
RickDC is infamous around these parts
Has anyone done an upgrade from their 2011-2014 Cayenne backup camera, to a 2015+? The resolution from the camera is awful and apparently the camera in the 2015 models is much better..
Thanks all!
Old Jun 14, 2018 | 12:15 AM
Elberoth's Avatar
5 Year Member
Elberoth is infamous around these parts
Not sure it will fit plu&play. From what I've been told, the on the 952.2 cars, there is no backap camera control module in the tailgate.
Anyway, I'm interested in your findings, as I have the 958.2 camera, which I would like to put on my 958.1 car, which has not been factory fitted with one.
Did you check the part #s for the 958.1 and 958.2 cameras ? Are they different to begin with ?
Old Jun 23, 2018 | 04:20 AM
G_A's Avatar
G_A
G_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of light
you should replace GW on FL version if want to use FL camera. as for me same poor image. Some china cameras better, but can be connected in 11-14 cars
Old Jun 23, 2018 | 10:50 AM
Elberoth's Avatar
5 Year Member
What is 'GW' ?
Old Jun 24, 2018 | 01:14 AM
G_A's Avatar
G_A
Gateway unit
Old Jun 24, 2018 | 01:36 AM
Elberoth's Avatar
5 Year Member
I have no backup camera right now. Only parking sensors (and PCM 3.1).
Would I be able to install the FL camera, when I buy the FL gateway module ?
If so, do you have the Porsche part # for the FL gataway module to look for ?
Old Jun 25, 2018 | 07:51 AM
Tom M's Avatar
Tom M is infamous around these partsTom M is infamous around these parts
I'd love to replace the camera on my 2011 as the factory unit really performs poorly in anything less than full daylight.
Is there an easy drop-in replacement? I know easy is not a good word as there's probably lot's of disassembly required to get the job done but I'm up for that if the replacement camera is plug & play.
Old Jun 26, 2018 | 01:42 PM
G_A's Avatar
G_A
do not know about simple camera replacement on 958.1 may be it will works, but parking lines will not be true imo. may be you can recalibrate camera with new eye, may be not - have to try. Oe camera powered not 12 Volts, but it is not problem. most 2011-14 cars can be coded as "camera low" - no additional control unit, no parking lines but better image with HQ not oe camera.
Old Mar 1, 2020 | 02:38 PM
carbon///m's Avatar
carbon///m is infamous around these parts
Curious if there is an update here for a pnP solution for 2011 camera w better quality.
Old Mar 1, 2020 | 03:23 PM
G_A's Avatar
G_A
no..
Old Feb 17, 2022 | 10:17 AM
012cs's Avatar
012cs is infamous around these parts
Anything?
any updates?
Old Feb 18, 2022 | 11:22 AM
Tom_T's Avatar
Tom_T is infamous around these parts
Thanks all!
Nav-TV was recommended to me by a Porsche Tech now with his own P-shop as the best for fitting to 955-957 or 958 Cayenne without the factory Back-up Camera option, so it should also work as an upgraded camera & hardware.
https://navtv.com/products/category/...e_cayenne.html
Cheers!
Tom
NoisyDante
Jan 6, 2016 12:38 PM
GMP Performance
Audi Vendor Classifieds
Jan 15, 2015 11:40 AM
tooch
Cayenne 955/957
Jul 29, 2012 08:18 AM
Wheelman
Aug 31, 2007 05:26 PM
paixim
Audi
May 22, 2007 01:43 AM
