Jukebox
Old Apr 5, 2017 | 09:52 PM
Joanna Woo's Avatar
Joanna Woo is infamous around these parts
Jukebox
Hi,
I just got my first Porsche and new to the site. I'm trying to figure out how to import music to the jukebox as I was told I can import CD'd to the jukebox hard drive. However, I can't find the option to import anything into it. Any advice is appreciated.
Old Apr 6, 2017 | 05:37 PM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
So Joanna - what did you get and what was the audio package in it? If it's the Bose or Burmeiser, starting with around 2014 or so - you could import MP3's from a USB stick to the hard-drive, and I think it had an option to import CD's as you play them. I had a loaner 2015 diesel for a month and imported my 4,000 tracks from a USB stick that normally lives in my '11 CTT. I know it took a bit of digging in the menus to find the option - I seem to recall it was at least 3 levels deep.
Old Apr 6, 2017 | 07:56 PM
Joanna Woo's Avatar
I have 2017 e hybrid with platinum package. Also has car play for my iPhone. I don't see the option to import anything to th Jukebox. I'm usually very computer savvy. So I'm not sure why I can't seem to find the options.
Options under Jukebox
Jukebox menu
CD options, no export to Jukebox possible
Source details for Jukebox
Old Apr 6, 2017 | 11:41 PM
Joanna Woo's Avatar
It's Bose, forgot to answer it last time.
Old Apr 6, 2017 | 11:42 PM
Joanna Woo's Avatar
It's 2017 Cayenne e hybrid. I couldn't find the option to import the tracks from CD's. I'm usually very computer savvy too, frustrated that I have not been able to do it.
Old Apr 6, 2017 | 11:43 PM
Joanna Woo's Avatar
Old Apr 7, 2017 | 06:41 AM
atwong1's Avatar
Emerging Sponsor
5 Year Member
atwong1 is infamous around these parts
No import from CD. You have use iTunes to rip the CD on a computer to AAC files and then import them using a USB. USB is inside the armrest. Why AAC, and not MP3? Because AAC can hold metadata, like coverart and artist data.
Old Apr 8, 2017 | 02:11 PM
I imported over 3,500 MP3 tracks from a USB thumb drive to the loaner 2016 Cayenne Diesel I had when my Turbo was in for service for a month. There is no problem at all in importing MP3's and MP3's can also store cover-art and artist data. No need to rip to AAC files. FreeRip (free Windows based RIP program) easily looks up the cover art for you and associates it with the MP3 track.
As far as importing from CD - it sounds as if the manual claims this can be done, and I know on other model cars it can be done (like BMW, Lexus) so I can't imagine it's not possible on the latest Cayenne audio. Why can't it be found? Dunno - didn't try it on the loaner..
Joanna - what happens if you select the "SET MEDIA" from the first menu level?
Old Apr 8, 2017 | 03:57 PM
Joanna Woo's Avatar
The manual makes it look like it could be done, to import CD/DVD's. Kinda disappointing not be able to do it.
http://www.porscheownersmanuals.com/...illing-jukebox
Old Apr 8, 2017 | 07:10 PM
Joanna - I'm seeing some conflicting messages on the display in your photos..
The top line tells me there is a DISC in the system - Beauty and the Beast.
Right under that is a message saying "Disk Empty"
Does this Cayenne perhaps have the 6-Disk CD changer mounted in the rear compartment (right side when you open the rear hatch - at least that's where it was in earlier Cayennes..)?
I think the trick will be - you have to pick the source - before the option appears to copy the music to the internal juke-box drive.
If you press "SET MEDIA" - what appears after that is pressed? Perhaps a photo might be enlightening..
Old Apr 4, 2020 | 07:13 AM
swflaguy's Avatar
swflaguy is infamous around these parts
I recently added music to the jukebox in my Boxster and assume it's a similar process in most of the Porsche models. Here's what I did -
- Chose a playlist in iTunes, selected all the tracks. Then copied all the tracks to a USB memory stick.
- Plugged the USB memory stick into the USB port on the Boxster, the engine was running, so do this outside. The transfer from USB to internal hard drive takes time. Without the engine running, some radios may shut down after 10-minutes. If so, you have to start the download again.
- I have a physical button for "media source". Selecting it pops up several options on the display - AM, FM, Sat, USB, Jukebox. Select USB.
-That should bring up a display screen that gives you the option to PLAY from the USB memory stick or COPY it to the hard drive. Obviously, select the "copy to hard drive". It's slowwwww, but you only have to do it once. Three Gigabytes (about 160 songs) took the better part of 25-minutes.
From there, you can select the jukebox as one of the sources just like you would AM, FM, Sat, etc.
Hope that helps.
forbes210
Feb 2, 2019 07:48 PM
PAJ
Apr 30, 2018 12:57 PM
SD Vidiot
Jan 2, 2016 06:25 AM
Money2536
Nov 2, 2015 01:06 PM
infiniteecho
Oct 14, 2014 06:48 AM
