DI Water
Old Oct 18, 2007 | 07:35 PM
FrankM's Avatar
FrankM is infamous around these parts
DI Water
I am seriously thinking about getting a CR Spotless, researching the threads on 6 speed it seems as if it does a good job. I presently have a water softener. I know weight wise the sodium in soft water weighs about half of the Mg & Ca in hard water after the ion exchange, but I think the ion exchange is 1 to 1. Would there be any difference in resin life running hard water of soft water thru the DI unit? I think it would be the same.
I currently use the Mr. Clean gun to rinse the car and it does a good job if you make sure and rinse it well, it just takes too long, water flow is low.
Are there any other systems available like the CR spotless?
Frank
Old Oct 18, 2007 | 08:25 PM
MoeMistry's Avatar
Premium Sponsor
Frank
There are other systems Frank, but the CR is the only one that works. Having a soft water system running prior to the the di does not change the parts per million, PPM, count. It only means you have Na, sodium, and Cl, chlrode molecules instead of Mg, magnesium, and Ca, calcium molecules. I'm going to have a group buy coming in the next few days. Are you interested?
Old Oct 18, 2007 | 08:31 PM
MidnighTT's Avatar
MidnighTT is infamous around these parts
Grab a CR system from Moe - you won't be disappointed! There's too much pollen where I live to air dry, but with the DI water all I have to do is grab 2 corners of my mf drying towel and pull it across the surface. No pressure at all.
When I did that with untreated water, the towel would leave water trails and spots behind. The DI water gets sucked right up, no water trails or spots (unless the towel is compeltely soaked, of course). I don't understand why DI makes this difference, but I have zero doubt that it does make the difference.
Jeff
Old Oct 18, 2007 | 08:49 PM
tblountman's Avatar
tblountman has a reputation beyond reputetblountman has a reputation beyond reputetblountman has a reputation beyond reputetblountman has a reputation beyond reputetblountman has a reputation beyond reputetblountman has a reputation beyond reputetblountman has a reputation beyond reputetblountman has a reputation beyond reputetblountman has a reputation beyond reputetblountman has a reputation beyond reputetblountman has a reputation beyond repute
CR spotless is the way to go. I got one a couple of weeks ago and was very skeptical and now I am a believer. My house has a water softener built in but I don't know if it helps or not.
Old Oct 18, 2007 | 08:56 PM
deputydog95's Avatar
deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !
Or you can just go down to your local water treatment store and buy a DI unit. That's what I did.
Old Oct 19, 2007 | 10:59 AM
FrankM's Avatar
I am interested in the group buy.
Old Oct 19, 2007 | 11:22 AM
steelth's Avatar
steelth is infamous around these parts
Please explain more in detail or PM info. I would love to make one myself for alot cheaper
Old Oct 19, 2007 | 05:54 PM
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
Once you start using the CR or any other DI that works you will never want to wash your car without one again.
Old Oct 19, 2007 | 09:06 PM
tblountman's Avatar
^^^^ +1
Old Oct 19, 2007 | 10:04 PM
oak's Avatar
oak
I'm interested in a gp. any info on this cr unit?
tia
Old Oct 21, 2007 | 10:20 PM
MoeMistry's Avatar
Premium Sponsor
Bmw M3 Guy
Feb 21, 2018 09:29 AM
kristoffer
Cayenne
Dec 20, 2015 03:02 PM
cerbomark
Sep 22, 2015 03:32 PM
