Tree sap on rag top
Old Sep 19, 2012 | 08:26 PM
Porschejeff's Avatar
Porschejeff is infamous around these parts
Tree sap on rag top
Any suggestions on how to remove some tree sap on my cabrio rag top?
Old Sep 19, 2012 | 09:08 PM
djantlive's Avatar
i have just used car wash in the past.
Old Sep 19, 2012 | 10:10 PM
sixgun95's Avatar
sixgun95 is infamous around these parts
I would use 303 Fabric cleaner, then use Raggtop cleaner and protectant. That should do it.
Old Sep 20, 2012 | 02:33 AM
TOGWT's Avatar
TOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to behold
Tree Resin (Sap) – place a 1:10 solution of Isopropyl alcohol on the resin and allow to dwell (soak a towel and lay it on the resin) and then scrape with a plastic razor blade. Thoroughly rinse surface with clean water and then replace protection
Old Sep 20, 2012 | 04:32 AM
jacques1960's Avatar
jacques1960 is just really nicejacques1960 is just really nicejacques1960 is just really nicejacques1960 is just really nice
91% isopropyl alcohol is one option; another is to purchase a can of compressed "air", invert and freeze the sap, which can then be scraped off
Old Sep 20, 2012 | 11:45 AM
MoeMistry's Avatar
Premium Sponsor
That's a neat technique. Have you done it with great results?
Old Sep 20, 2012 | 01:12 PM
Yes - the inverted can is SOP for chewing gum in carpet. Isopropyl is only solvent which will remove sap without damage. As always, test small area first
Old Sep 20, 2012 | 10:51 PM
sixgun95's Avatar
Excellent! You are the man!!!
Old Sep 22, 2012 | 03:04 PM
Thanks guys, I will try the inverted canned air first. I have the Raggtopp protectant for after it's removed.
Old Sep 22, 2012 | 05:05 PM
911Konigin's Avatar
911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of911Konigin has much to be proud of
Will alcohol also work on the body?
Old Sep 23, 2012 | 05:41 AM
TOGWT's Avatar
“Removal of Tree Resin / Sap” - http://www.autopia.org/forum/autopia...ml#post1499766
I hope the information in this article is of some help to you. If you have any further questions please let me know
Old Sep 24, 2012 | 04:52 AM
Yes, 91% isopropyl works extremely well on the body.
For rag top, if you need to raise the "nap" of the fabric after cleaning, use a bronze bristle brush (gently) which is available at most shoe repair stores (normally used to raise the nap / clean suede products)
pshep138
Oct 6, 2015 11:58 AM
BLKMGK
Sep 19, 2015 03:51 PM
DetomasoGTS74
Sep 7, 2015 09:42 AM
Wildcat1212
Sep 5, 2015 05:35 PM
AdPock
Ferrari
Sep 1, 2015 10:13 PM
