Panamera resonator bypass
Old Mar 18, 2018 | 07:27 PM
moose loose's Avatar
moose loose is infamous around these parts
Hello,
I found this online in my city : wil it fit panamera 2012 base ( it says on the ad panamera turbo)
thank you
Old Mar 19, 2018 | 02:29 PM
Answer from fabspeed :
These parts not interchangable as the sizing is different between a turbo and non turbo model.
too bad I thought they could be just welded
Old Mar 20, 2018 | 12:18 PM
striped91's Avatar
striped91 is infamous around these parts
Any reputable exhaust shop would be able to make this work with your car. Check around for adapters if you want to bolt it in yourself.
Old Mar 20, 2018 | 01:30 PM
Thank you for the answer
I won’t do it myself, the exhaust shop will weld the pipes or bolt them ?
I thought the pipes were larger and no space to make them fit
the tubing and end sizes are different ?
can you please confirm
Old Mar 21, 2018 | 07:00 AM
striped91's Avatar
A good exhaust shop will have everything needed to attach differing diameter tubing. Tell them the car you have and the diameter of the Fabspeed part you want installed. They should be able to tell you if they can do it. BTW the Fabspeed muffler package that I put on my 2012 V6 Panamera came with adapters made by Fabspeed. The adapter was about 6 inched long. The larger end attached to the Fabspeed tubing and the other end attached to the OEM tubing.
Old Mar 21, 2018 | 09:29 AM
ok thank you so much !
fabspeed answered me again it is possible :
‘’ Of course, anything is possible with the right tools and skills for fabrication. Please though, be aware that when fabricating and welding this tubing is 304 stainless steel and has to be welded accordingly. TIG or MIG welding only. ‘’
Old Apr 17, 2018 | 02:47 PM
Hello,
I installed the fabspeed xpipe and put new tips, removed 3 resonators but the sound is very raspy... I know it is a V6 but I’m so unhappy with it... check the video
will a muffler delete be a deeper sound ? (And way too loud)
Thank you
Old Apr 22, 2018 | 08:15 AM
Originally Posted by moose loose
https://youtu.be/smODVKGkCRU
Hello,
Thank you
any suggestion would help
thank you
Old Jan 22, 2019 | 08:31 AM
XLR82XS's Avatar
Like I mentioned before, muffler delete would give you a big bump in sound. If it's too loud you can always reinstall the factory mufflers then procure an inexpensive aftermarket axle-back system.
Chris_FL
Sep 5, 2014 05:00 AM
Crod
Jan 24, 2014 10:17 AM
golfman
Oct 7, 2006 10:46 PM
