Need so help with front struts and hood-Major Help needed
Old Jun 28, 2020 | 05:10 PM
gvenz33's Avatar
gvenz33 is infamous around these parts
Ok, I just encountered 2 issues that I really need help with because my 2011 Porsche Panamera is undrivable. I am panicking!
1. my hood stopped opening. I really don’t know what happened here but when I try the hood release lever I can no longer open the hood to gain access to the engine. Is there a way to manually bypass this and get the hood opened so I can find out what the issue is?
2. I had Panamera sitting in the driveway for about 2 weeks. The front struts are now slammed to the ground and won’t refill when I turn on my car. The compressor works. I see the rear struts inflating but the fronts aren’t and don’t know what to do. Is there a way I could manually inflate them?
any and all help would be greatly appreciated. Thank you
Old Jun 29, 2020 | 12:18 AM
vkb123's Avatar
5 Year Member
vkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond reputevkb123 has a reputation beyond repute
Can’t help with hood release. Suspect your front air suspension struts are leaking. Well know issue. Ciaka has done a great write up on the air suspension set up and a DIY on the strut replacement:
https://www.6speedonline.com/forums/...ent-front.html
Stuts are expensive. If compressor is running then compressor and relay (also known issues) are working. Careful, can fry your compressor as it works overtime to try to inflate leaking struts. Good luck!
Old Jun 29, 2020 | 04:35 AM
jzchen's Avatar
5 Year Member
jzchen is infamous around these parts
I had the hood get stuck a couple of times. If you felt the cable resistance when you pulled the release, the same feeling as when it works, carefully try to pry up on the edge of the hood. With 8 fingers on it mine popped right up, then I was able to reach the secondary release as usual.
​​​​​​Both front struts at the same time seems a little unusual from just sitting. I ended up leaving the triangular shaped covers off so I can easily check the condition of the top of the spring/strut. A little soapy water and observing when you turn the car on should show whether they are leaking or not.
Good luck and let us know....
Old Jun 29, 2020 | 06:57 AM
Deezflip's Avatar
5 Year Member
Deezflip is infamous around these parts
dudecs posted this for someone that had this similar hood issue not too long ago
https://www.6speedonline.com/forums/...y-release.html
https://rennlist.com/forums/panamera...-panamera.html
Old Jul 17, 2020 | 10:20 PM
gvenz33's Avatar
I finally got around to this earlier and was able to remove the lever and check the cable there. The cable is entice but even when I pull on the cable with pliers I get some tension but know pop for the hood latch.
Is there an emergency Hood release loop for this? Seems like there has to be something in case something like this happens.
i can’t get to the struts but today when the compressor came on, it did look like it was pumping air into the strut and I was able to hear air leaking from the front right strut. Just need to get to it now.
Old Jul 18, 2020 | 12:20 PM
DavidIn's Avatar
5 Year Member
DavidIn is infamous around these parts
This may help with opening your hood:
https://www.6speedonline.com/forums/...a-4s-hood.html
Old Jan 18, 2022 | 08:34 AM
Corybory's Avatar
Corybory is infamous around these parts
Hood problems
How did u get the hood open on the porsche. Mine is stuck. Could use help! Thanks
Old Jan 18, 2022 | 08:45 AM
gvenz33's Avatar
Hopefully yours isn't as bad as mine. We had to completely take out the front end, left fender, wheel well liner. Then we created a makeshift tool to release the latch because a little black piece that was holding the cable snapped off on the latch unit. The Panamera has a stupid design where it doesn't have an emergency manual release.
The easier route would be if the cable got displaced under the dash.. Hope this kind of guides you.
Old May 3, 2022 | 03:35 AM
negb's Avatar
negb is infamous around these parts
So to replace hood release cable even fender has to be removed??
On mine Panamera hood release is still functional but I see several cracks on cable, bought new cable, was under impression that won't be a difficult job, like I did on few other cars....
Old May 3, 2022 | 06:50 AM
gvenz33's Avatar
I took the panamera to one toy mechanic friends who ordered a new hood latch. Such a ridiculous design. So after removal of the fender, bumper, and a bunch of other stuff, they created a little hook took to pry open the latch and release the hood. It was really a painful process. Porsche did jot design this properly. They should have also provided a manual override pull for this purpose. If you are able to release and open the hood. Release the cable asap. Fishing the van through its path shouldn't be too bad but of the hood gets stuck... that's going to be a nightmare.
Old Jul 8, 2024 | 12:17 AM
Panamera2010's Avatar
Panamera2010
would you please send a picture or a diagram of your "makeshift tool" and try to explain where exactly you placed it and which way you pulled (as if ypu are looking at it while sitting behind the wheel). Thank you kindly in advance
ss360
993
Jul 17, 2020 10:15 PM
rich022
Cayenne 958
Jun 1, 2019 11:01 AM
machinegunt
Aug 5, 2013 03:49 AM
PorscheEnvy
Nov 16, 2007 09:42 PM
yellowbmr
Dec 27, 2005 08:50 PM
