Panamera Engine Mounts Replacement
Old Jan 29, 2021 | 03:27 PM
Mccullum55's Avatar
Mccullum55 is infamous around these parts
Hi!
New to the group. Does anyone know where I can get DIY info on changing engine mounts on a 2013 Panamera or where I can find a repair book? Any info will be greatly appreciated! Also any info on parts that are cheaper than the dealership!
Mac
Old Jan 29, 2021 | 07:41 PM
sunnyc123abc's Avatar
sunnyc123abc is infamous around these parts
What I've read on ALLDATAdiy.com is that you need to remove the ac compressor, raise engine with engine supports, and then remove motor mounts. For parts try fcpeuro, they have lifetime replacement warranty.
Old Jan 29, 2021 | 10:26 PM
Mccullum55's Avatar
Thank you.
Old Jan 30, 2021 | 05:49 AM
Porsche Pana's Avatar
Porsche Pana is infamous around these parts
Did you change the engine mounts by yourself? Do you have a DIY
Old Feb 4, 2021 | 08:44 AM
ciaka's Avatar
As far as I know, replacing the engine mounts is not very DIY. I have not come across anyone who did this DIY. Would be great to have diy for it though.
Old Jun 13, 2021 | 12:39 PM
finnpat7's Avatar
finnpat7 is infamous around these parts
Panamera motor mounts
Im trying to figure this out too. There is no where to push the engine up. Im not comfortable raising motor off the plastic oil pan.
Old Jun 14, 2021 | 04:44 AM
shrike071's Avatar
shrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud ofshrike071 has much to be proud of
Use a hoist - do not "push the engine up".
Old Jun 15, 2021 | 02:35 PM
DogWood's Avatar
5 Year Member
DogWood is infamous around these partsDogWood is infamous around these parts
"normal Fellow" has done it, I gave him a heads up and I thought he was going to post here.
Old Dec 28, 2021 | 12:37 AM
Hi. Have you an idea how i can change the engine mount. I have a v6 rear wheel drive. Can I only take the ac compressor down and the bracket on the drivers side.
Old Dec 28, 2021 | 07:56 AM
DogWood's Avatar
5 Year Member
sorry I've never done it and I have a V8, you might try messaging Normal Fellow and see if he might have an idea (he did it on his Turbo)
Old Jan 3, 2022 | 02:09 PM
JPhi1618's Avatar
JPhi1618 is infamous around these parts
I found this YouTube video of a shop doing it on a lift.
Yea, it's not DIY, but its pretty close. It might not be any where close to the "official" way to do it, but least it shows the steps involved. They do use a jack to push the engine up.
sinKing
Dec 1, 2019 05:56 PM
OK51MON
Apr 2, 2016 12:45 PM
PelicanParts.com
Feb 10, 2016 11:54 AM
