Tuning/Modifications
KA - In Memory of my Mom (Vincee) and best friend Michael J. Maring
Old Sep 23, 2006 | 08:50 AM
  #2161
Phoenix's Avatar
Phoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant future
Chad,
Regarding your CF hood.......was it custom made?
Thanks.
Old Sep 23, 2006 | 02:40 PM
  #2162
sharkster's Avatar
Originally Posted by Phoenix
Chad,
Thanks.
is there are a part on his car that isn't? I was trying to come up with a "stock" part for his motor but couldn't....
Old Sep 23, 2006 | 02:57 PM
  #2163
Craigger's Avatar
Craigger is infamous around these parts
AC unit?.....
Old Sep 23, 2006 | 03:06 PM
  #2164
CLS's Avatar
CLS
CLS is infamous around these partsCLS is infamous around these parts
Originally Posted by cjv
Alex,
Meeting you last night at Sharkwerks was a hoot. I have never been to your place of business before. My friend Craig simply asked me to follow him to some shop at 8:00 PM so he could drop off his car and then give him a ride home. When we get there he bangs on the rear door and the rolling door opens up. The first thing I saw was your license plate on what appears to be your car partially disassembled and up on a rack and I begin to wonder what is going on.
Then I saw you walking up.
It was great seeing you again after all this time. I asked Craig, why didn't you say you were taking your car to Sharkwerks. I could have told you it would be in good hands.
Hey just a quick note to thank Sharkworks, Alex and Steve, for doing such a great job setting up my car with the PSS9 and the H&R sway bars I was All the way home when I picked it up...I even decided to take a detour to just check it out more. Had the guys at Custom Alignment do a corner balance check and Alignment the next day and they said it was set-up great no adjustment needed on the corner balance slight alignment required that to be expected . Thanks again for a great experience!!!
Old Sep 23, 2006 | 03:10 PM
  #2165
CLS's Avatar
CLS
Originally Posted by Craigger
AC unit?.....
I believe the question was is there a stock part left on the "Motor" not the car
Old Sep 23, 2006 | 04:31 PM
  #2166
Craigger's Avatar
I always thought the AC unit was bolted to the motor. ergo part of the motor.
but alas, comments in jest never come across
Old Sep 23, 2006 | 06:41 PM
  #2167
cjv's Avatar
cjv
Moderator
No, there isn't one stock part in this motor.
Old Oct 5, 2006 | 06:41 PM
  #2168
JarodL's Avatar
JarodL is a glorious beacon of lightJarodL is a glorious beacon of lightJarodL is a glorious beacon of lightJarodL is a glorious beacon of lightJarodL is a glorious beacon of lightJarodL is a glorious beacon of light
Chad what ever happened with the cams?
What is the ETA on completion?
Old Oct 6, 2006 | 02:01 PM
  #2169
cjv's Avatar
cjv
Moderator
Jarod,
We used GT3 street intake and exhaust cams with a shortened duration and extended lift.
Not sure on the completion as we are having some trouble with the company who did the head work. I'll get into that later.
Old Oct 18, 2006 | 10:14 AM
  #2170
JarodL's Avatar
1,058 views to go until your car has to be ready Chad. What do we win if it isn't?
Old Oct 18, 2006 | 08:59 PM
  #2171
cjv's Avatar
cjv
Moderator
JarodL,
Hmmmmm............. I'll have to think about that one.
Back to the schedule ........... how about seven weeks. I'm at liberty to say a little more. How many people realize the GT3 Street, GT3 Cup and GT3R motors all have a different number of cam pointers? Each cam requires different ECU's. Now to make matters worst there are solid and hydralic tappets along with different GT3 year models have different tappets with different overall dimensions and designs. If the above isn't bad enough, try welding metal any one of the above stock Porsche GT3 cams using the required Porsche tappets. Well, it may work for awhile, but the different metals (cam and tappets) will quickly wear down the welded lobes. So what do you do?
All of the people to date who have turbocharged the GT3 heads have used either the stock GT3 street or GT3 Cup cams with the respective tappets. The problem is you don't have a crisp or responsive motor. You have a motor that is fast but far from optimum. You have a turbocharged motor with a normally aspirated cam profile. Not good to say the least. You have to do strange things to the timing and the performance suffers in many areas. Furthermore, you have these huge GT3 heads with a cam that can't make real good use of these monster heads breathing wise. Some people have used stock turbo heads that are ported and valved to GT3 dimensions. This is great ............. but how about the tappets. They simply won't stand up to anywhere near 8500 rpm's. We know of no one prior to S Car Go Racing who has made a turbo cam for the GT3 heads that is compatable with existing tappets and ECU's. The S Car Go turbo cams (intake and exhaust) for the GT3 heads will be proven before the end of the year. My prediction is no street 996tt or turbo GT3 to date will come close to KA in power, torque, longevity and crisp responsive drivability throughout the entire rpm range.
Old Oct 19, 2006 | 12:13 PM
  #2172
sharkster's Avatar
Heya CJV... sorry I'm muddled here but does this still mean you are using a GT3 ECU to start with or have things changed? Seems like the hardware battle is still more of a challenge than the software one
Old Oct 19, 2006 | 11:59 PM
  #2173
cjv's Avatar
cjv
Moderator
We are using the 996tt ECU but not the 996tt software. This way no smog failure. The downside is the stock boost control gauge doesn't work. No biggie as a mechanical gauge is being added. In addition the 996tt ABS won't operate so we are using a much faster accumulator and related software.
There is no more battle, all issues have been resolved.
Old Oct 23, 2006 | 03:57 PM
  #2174
cjv's Avatar
cjv
Moderator
Out of curosity, are there any 6 speed members who had their motor tuned on an engine dyno versus a chassis dyno?
Old Oct 23, 2006 | 05:52 PM
  #2175
VRAlexander
Guest
Posts: n/a
You knew that mine was done of both...Just a heads up on Todd's engine dyno....it is on the CONSERVATIVE side .
You have already rated this thread Rating: Thread Rating: 90 votes, 4.16 average.
