Starting down the slippery slope - '87 930 3.3L Rebuild EFI Conversion
Old Mar 22, 2011 | 06:14 PM
CaptainCalf's Avatar
CaptainCalf is infamous around these parts
Last Sunday I bought a 1987 930 that had been sidelined by a broken head stud. The PO started the project and did a lot of great work, but has now passed the torch to me. This will be a beautiful puzzle
I started out last night by measuring the cylinders for bore spec, roundness and taper...all is well!
Old Mar 23, 2011 | 07:59 AM
APR rod bolts
Measuring rod/crank clearances now
Old Mar 23, 2011 | 07:38 PM
Fire Rings
Anybody know if I have room for fire rings in these cylinders & heads?
8-8.5mm for head width
2.5-3mm for cylinder height
Old Mar 24, 2011 | 05:18 PM
Plexiform's Avatar
Plexiform is infamous around these parts
congrats on the purchase. hope the rebuild goes well. good luck! keep the pictures coming.
Old Mar 24, 2011 | 05:49 PM
Will do!
I've got more pics right now but not smart enough to get them to upload from my iPhone
Old Mar 24, 2011 | 06:32 PM
Bearings R Us
conrod & main bearings
Old Mar 25, 2011 | 06:06 AM
more pics
bearings, case & stand
Old Mar 27, 2011 | 07:05 PM
more pics
rod brg clears are good, turbo pump is clean and rockers need resurfacing
Old Mar 27, 2011 | 07:07 PM
pump
turbo pump cleaned & almost ready to use
Old Mar 30, 2011 | 01:55 PM
ErikG's Avatar
ErikG is infamous around these parts
I'll follow along. Would love to do one of these myself but don't think I'm **** enough to make sure all measurements and clearances are within spec. My motor was build with EFI in mind (Motronic), but just seems sooooo expensive.
Old Mar 30, 2011 | 07:52 PM
Nothing worth having is cheap
Old Apr 5, 2011 | 12:17 PM
pump is back together
more pics
Old Apr 6, 2011 | 07:56 PM
Piston ring to land clears all well within spec
more progress
Old Apr 7, 2011 | 09:10 AM
ErikG's Avatar
you're not going with 3.4's ?. As it was explained to me, main reason why Ruf went to 3.4's is that the cylinders had fins all around which was better for cooling. If stock ones are perfect I guess it is a good money saver.
Old Apr 7, 2011 | 09:21 AM
Fins
If these Mahle's weren't so bullet proof, I'd be upgrading to 3.4s after their 24 year 120,000 mile life, but they are absolutely metallurgy masterpieces
