The Old Wastegate Issue
Old Dec 29, 2007 | 08:10 PM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
I wish someone can give me a straight forward process to adjust the wastgates, I hear some measure the length of threaded rod at the end equally, but know of some that say when measured with pressure testing the rod can be uneven at the end. I know Kevin has a write up, and this is a measuring process also. What's the real deal?
The way I done it once was make sure the gate was closed then measured 3mm back (so there was 3mm pull on the gate with the rod) and locked it up at that!
I have k24's and the 1bar spring wastegate and starting from scratch again.
Old Dec 29, 2007 | 08:53 PM
DERBOOST's Avatar
DERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of light
https://www.6speedonline.com/forums/...ate+adjustment
I set mine to .005" movement at 12 psi, this gives 1.3 bar at WOT, I used a very accutate 0-15 psi air guage and a small hand operated air pump.
Old Dec 30, 2007 | 04:22 AM
Thanks for this Derboost, I knew a few would hardly reply to this as the thread has been beaten to death, but the reason I posted was there are so many conflicting threads that it just don't make any bloody sense at all! Thanks again
Old Dec 30, 2007 | 05:17 AM
Mikelly's Avatar
I took a dial caliper and set up mine (K16/24s) as Kevin suggested... 32MM from the back of the most forward nut (closest to the spring housing) to the end of the rod. I then took a motiv brake bleeder and cut the hose with the master cylinder cap off (I'll reconnect it with a brass adapter) and used the motive to provide pressure to the actuator. I measured the right unit with 8 pounds of pressure and captured the movement with a dial indicator with a magnetic base. Be prepared to remove the heat sheild on the right side turbo to get to the rod. I measured .005 movement... I moved to the right side and set it up with the same amount of pressure and got .004. So I adjusted that rod out a hair and got it to .005!
I'm now boosting a solid 1.1 and flashing 1.2 boost. I'll wait until I get Kevin's clutch upgrade before I try to get a solid 1.2 boost at WOT consitantly.
So you need a dial caliper, a ruler with milimeters indicated to help baseline everthing is nice too. A dial indicator, and a way to get a steady state of pressure to the wastegates. Using the motiv with some vacuum tubing and a stepdown adapter seemed to work well for me.
Mike
Old Dec 30, 2007 | 05:25 AM
oak's Avatar
oak
kevin, fyi, mentioned that they should be synched together in tandem with right and left dial gauges set up simultaneously and a single pressure source.
Old Dec 30, 2007 | 05:42 AM
Mikelly's Avatar
Well when I specifically walked him thru how I was doing it, he said it would be fine like that. I even DIY'ed it in his thread on Rennlist.
Mike
Old Dec 30, 2007 | 05:49 AM
oak's Avatar
oak
I'm sure it's not that critical. just if you want to really dial them in mucho get's them homed.
Old Dec 30, 2007 | 05:54 AM
Mikelly's Avatar
Damnit Oak, Now you have me thinking... I have a brass "T" sitting on one of my work benches too!
Mike
Old Dec 30, 2007 | 06:04 AM
oak's Avatar
oak
hey what do I know? I try and keep an open mind, but not too open to become a trash recepticle....
Old Dec 30, 2007 | 06:17 AM
Mikelly's Avatar
Old Dec 30, 2007 | 06:40 AM
DERBOOST's Avatar
I do know that when building all our smallblock twin turbo motors it was imperative to the tune that the turbo's were running the exact same pressure. When they were connected to a common intercooler, it did not matter, but with 2 separate coolers it was a must. If the pressure was not the same you had the 2 banks of the engine with different egt's, thus 2 different fuel maps,timing curves, ect etc etc.......just my 2 cents....
Old Dec 31, 2007 | 03:56 AM
jimmer23's Avatar
jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !
The 2 banks for the 996TT are joined by the Y-pipe before entering the engine through the throttle body. This way the pressure/boost is equally distributed into the engine so the EGTs should be perfect for each side. No harm if the turbo wastegate adjustments are off a little.
Old Jan 1, 2008 | 07:23 PM
chenshan's Avatar
chenshan is a jewel in the roughchenshan is a jewel in the roughchenshan is a jewel in the rough
this is what I done.....
adnanm3
Nov 22, 2023 02:43 AM
PV=nRT.
Sep 9, 2022 06:06 PM
Paintballzen
Oct 10, 2020 12:22 PM
Jeanmarcboilard
Sep 22, 2015 05:03 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
