Injectors...
Old Aug 21, 2008 | 05:18 PM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
Injectors...
Hello guys...i ve just bought and installed a set of k24/18gs.I am about to buy some injectors as well.My question is how difficult is to replace the injectors,without removing the turbos and the engine...Is it possible?
Old Aug 21, 2008 | 05:41 PM
unvmy996's Avatar
the injectros and adapters are a royal ***** the ! (gamise ta megale) you dont have to drop the motor compeltely u can just drop it a few inches and you will be good to go.
Old Aug 21, 2008 | 07:39 PM
maxboost's Avatar
maxboost is infamous around these partsmaxboost is infamous around these parts
droppin the powertrain/drivetrain is so easy. 1hr
Old Aug 21, 2008 | 07:52 PM
kilrgt's Avatar
kilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to beholdkilrgt is a splendid one to behold
Do you really need them? I am not saying either way but they are a *****, I changed mine and the next time I will pay someone..
Old Aug 21, 2008 | 10:13 PM
DEEPBLUE's Avatar
DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !
I'll let you know Saturday night :-)
Old Aug 21, 2008 | 11:23 PM
John D's Avatar
John D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to beholdJohn D is a splendid one to behold
I have a set of 60 lb. injectors for sale if anyone is interested. $250.00 for the set of six.
Old Aug 22, 2008 | 07:23 AM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
John - why you selling your injectors?
what brand are they?
Old Aug 22, 2008 | 07:26 AM
tom kerr's Avatar
why? I have the same set up, dynoed at over 600 hp with 85% injector duty cycle. I dont think it is necessary??
Old Aug 22, 2008 | 08:13 AM
onelove's Avatar
onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !onelove Is a GOD !
You made over 600hp on factory injectors, and where only at 85% duty ? What dyno was this on, sounds a bit high to only 85% from what I've seen, especially given the current heat/humidity here in FL.
Old Aug 22, 2008 | 08:58 AM
tom kerr's Avatar
Sea and Air at SRP (or something like that) and that was 528 rwhp to be exact.
also really not my point. which was this set up is pretty good and I looked into the whole injector thing and was told by multiple people smarter than me (Todd, Protomotive) it wasnt needed. has he told you different?
I'll be at Sebring tomorrow if you are coming down?
Old Aug 22, 2008 | 09:28 AM
onelove's Avatar
I thought you meant 600 wheel hp, at which point the 85% duty cycle would be very difficult to believe without injectors. At 530 I do not think the injectors are necessary, however if you're looking to make a bit more power and you're already dropping the engine to install turbos, my new belief is that the injectors might be a cheap safety net in the overal big picture and allow for easier additional power upgrades down the road. My next car will get these when I do turbo upgrades to it.
We've got a race an ADRL race in Ohio this weekend with our race cars so unfortunately won't be out at Sebring, I'm hoping to make it out there next month for the PBOC event but have to see what the schedule allows.
Old Aug 22, 2008 | 11:05 AM
tom kerr's Avatar
catch the PCA night DE next month!!
Old Aug 24, 2008 | 09:56 PM
DEEPBLUE's Avatar
Skandalis-
I changed my injectors (rails and plugs too) yesterday- you can do it without dropping the turbos, IC's etc...you will need to lower the engine 2-3 inches though, which is much easier than it sounds, good time to swap motor mounts (I have some X73s for sale:-).
You will have to remove the fuel filter and air intake pipe on the driver side, need to remove the Y pipe and then air pump on the passenger side. Driver side is relatively easy, passenger side more complicated mostly because of the wire harnesses in the way. This will take you a good part of the afternoon, but plan an entire day in case of uh-ohs and have someone qualifed there to make sure you dont fubu.
couple tips- let car sit overnight to discharge fuel system, engine cool down and otherwise lots of fuel to clean up. Use vaseline or porsche lube on injectors, this will help installation quite a bit. Get an extendable magent and mirror, you will drop things. Dont use a jack that leaks... be patient, have fun.
To be honest my turbos are out for repair as well as intercoolers, heat shields etc, but this had no difference on the injectors and rails.
str8blst
Oct 20, 2011 02:54 PM
Mad Ness
Mar 4, 2010 08:33 AM
phillym5
Aug 16, 2009 10:05 PM
DNugget991GT3
Aug 22, 2008 07:03 PM
JoeyG
Apr 10, 2006 09:29 AM
