Newbie: Broken indicator stalk return function
Old Jun 21, 2010 | 11:58 PM
Griffon345's Avatar
Griffon345 is infamous around these parts
Hi all, a great source of info and entertainment, thanks.
I've looked at a couple 996's recently and at least half seem to have a problem with the return function of the turn signal stalk. These take the form of either;
not 'holding' in place once selected and/or
not returning/canceling after the turn is completed.
Is this a common fault on the range and does anybody know if this a a fix or a replacement?
Thanks in advance. BTW I did a couple searches but didn't find anything (dunno if my expat english let me down though)
SLR
Old Jun 22, 2010 | 08:16 AM
landjet's Avatar
This is the first time I have ever heard of this problem. It is not common at all.
Old Jun 22, 2010 | 08:23 AM
ColoradoSilver's Avatar
ColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud ofColoradoSilver has much to be proud of
This is a common issue.
There is a broken piece of plastic inside the steering column that is a part of the return feature of the indicator. Many 996 owners have had this issue. This little piece breaks off and falls into the column somewhere. Impossible to retrieve without taking apart the whole column and this includes removing the steering wheel and original indicator assembly.
The entire steering wheel, and stalk assembly will have the be removed and new assembly installed.
The part is a little over $200 and the labor of the job at the dealership is a little over $600.
It's an easy fix, just costly and time consuming.
Old Jun 22, 2010 | 10:10 AM
g8rdmd's Avatar
g8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to beholdg8rdmd is a splendid one to behold
I agree... Mine's been that way since I bought it--I've learned to manually cancel the left turn signal and hold the right turn in place myself. I'd rather put the time and money to more "entertaining" mods
Old Jun 22, 2010 | 10:23 AM
Ray C.'s Avatar
Ray C. is infamous around these parts
First time I have heard of this issue. I had a 99 C2 up to 58k and currently my 01 TT with 42k miles without this problem.
Old Jun 22, 2010 | 10:48 AM
80shilling's Avatar
80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !
I had the exact same thing happen to me.. The replacement part is $250-$300.. I am waiting to get my Car in the shop to get it taken care of. I found the little black plastic "tab" lying on the driver's side floor. It happened because I was making a turn and held the stalk as I turned.. It caused the tab to break off.
Old Jun 22, 2010 | 02:49 PM
dog4delta's Avatar
dog4delta is infamous around these partsdog4delta is infamous around these parts
The stalk can be had cheaper (Porsche part) through Suncoast or Sunset. I think I paid less than $200 shipped. Despite earlier posts, this is not all that uncommon.
The stalk assembly is not too difficult to change. There is a good DIY out there on how to remove the steering wheel, and it covers removal of the stalk assembly as well. No special tools required other than some Torx drivers, some modest skills, and some patience. Took me a little over an hour taking my time and working carefully. No way it should be a $600 fix at the dealer, unless they are charging over $300 an hour for labor!
Old Jun 22, 2010 | 03:19 PM
ttboost's Avatar
Bunch of Hamfists...it's only plastic...
Old Jun 26, 2010 | 04:19 PM
Griffon345's Avatar
Excellent info folks, seems the ones I looked at had the "ham fisted" drivers Ill get the part and do it myself, $200 seems for for the whole unit. I wonder if the 4 stalk unit mentioned in other posts for the computer could be used as a replacement?
Old Apr 30, 2012 | 02:20 PM
AngelOfGrief's Avatar
AngelOfGrief is infamous around these parts
Just writing to confirm I have exactly the same problem: need to hold the stalk when turning right and it won't return when turning left. It was fine when I bought the car and I was the one who broke it. ;(
Found a video on youtube on how to replace it:
Seems a pain to do since airbag assy is involved. Also the part is pretty hard to get in Russia, will either need to buy a used one or fix the original.
Partno is 996.613.21910 BTW.
Old Apr 30, 2012 | 06:57 PM
Etchhead's Avatar
Etchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond repute
My function stock is really loose- feels like its about to fall off... maybe similar issue?
Old Apr 9, 2014 | 05:41 PM
TMWTP's Avatar
TMWTP has a spectacular aura aboutTMWTP has a spectacular aura aboutTMWTP has a spectacular aura about
Update on pricing. Suncoast currently has this part for $235 + shipping. Mine just broke today.
Old Apr 9, 2014 | 07:31 PM
'02996ttx50's Avatar
i never touch that sucker, unless i have to lol. certainly never cancel it manually, pre auto cancel!
PV=nRT.
Sep 9, 2022 06:06 PM
ant_8u
Apr 10, 2016 11:42 AM
Vic55
Sep 14, 2015 09:42 AM
studlee
Sep 6, 2015 11:19 PM
