pirelli 335
Old Nov 11, 2010 | 09:22 AM
dynamic gt2's Avatar
dynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to behold
pirelli 335
Hello,
i want to replace my rear tires,they are 315/30zr18 but i dont find this size in Lebanon.i found 335/30/18 P zero rosso.What do you think?
Ali
Old Nov 11, 2010 | 11:33 AM
your opinion please
Old Nov 11, 2010 | 04:43 PM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
You will need to roll the fenders and trim the fender linings. They will work with some work. A lot easier to install 315s!
Old Nov 11, 2010 | 04:55 PM
raineycd's Avatar
GT2 already has rolled rears I think. Still will probably rub if not very careful.
Old Nov 12, 2010 | 03:13 PM
AtomicZ's Avatar
AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !AtomicZ Is a GOD !
I run 315's on the rear of mine. I think it would be difficult to stuff 335's.
Old Nov 12, 2010 | 09:10 PM
drnano's Avatar
drnano is a splendid one to beholddrnano is a splendid one to beholddrnano is a splendid one to beholddrnano is a splendid one to beholddrnano is a splendid one to beholddrnano is a splendid one to behold
I run 335/30 18 Pirelli Corsas for the street and 335/30 18 R888s for the track.
Both fit the 996 GT2 fine. After a more aggressive wheel alignment the rears will rub less over bumps etc. My car is also lowered about 2cm at the rear.
Mind you, my dealership said that for 12 inch wheels the 335's are a little too wide and although they may give better straight line traction, they will flex through the corners and you may lose grip.
Old Nov 12, 2010 | 09:34 PM
Thanks.
Old Nov 13, 2010 | 02:23 AM
Turbo Fanatic's Avatar
The factory 12" GT2 wheels fit nicely with a 7mm spacer. Might give you that extra little bit extra clearance on the inside you may need. please post up if and when you do it!
make sure you match the fronts in terms of height. mayeb go with a 245 or 255 40 18. Although thsi is not as amuch of a concern with a GT2 since there is no PSM or viscous coupling for the AWD to worry about
Old Nov 14, 2010 | 08:29 AM
335/30/18 Pzero rosso treadwear 160.
the traction is excellent,before i had lot of spinn on 1st and 2nd gear,now it is perfect.
randalldahme
Feb 19, 2016 03:56 PM
johnspeed
Oct 1, 2015 09:17 AM
WheelB
Sep 30, 2015 10:19 AM
Sep 25, 2015 10:10 AM
