DIY: Ride Height Measuring Device
Old Apr 23, 2013 | 05:34 PM
sammyf's Avatar
sammyf is a glorious beacon of lightsammyf is a glorious beacon of lightsammyf is a glorious beacon of lightsammyf is a glorious beacon of lightsammyf is a glorious beacon of lightsammyf is a glorious beacon of light
I've had my V3 coilovers for a while and they've fully settled. The shop that did the install originally used the fender measuring method, which is ok. But I wanted to be more precise and do it the factory way.
After searching for the factory ride height specs (I used the GT2 specs) and locating the appropriate measuring point... I realized that I had to devise some method to measure it. So I came up with the following:
1/2" x 3 1/2" Bolt and 1/2" nut plus 1/2" PVC pipe:
Used a piece of tape to mark off a ~80mm section of PVC pipe:
Cut it down using a band saw:
For some extra precision, I turned the piece of pipe on a lathe to get a perfectly even edge:
Next I epoxied the nut onto the section of pipe:
Then if you remember, the bolt also had some lettering stamped into the head, which I removed using the lathe (you will understand why later):
After epoxy was dry, I threaded the 2 parts back together and will be using this to "measure" the ride height:
Old Apr 23, 2013 | 05:55 PM
WILLIAMP's Avatar
WILLIAMP is infamous around these parts
And then...???
Old Apr 23, 2013 | 06:45 PM
King James's Avatar
King James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond reputeKing James has a reputation beyond repute
Originally Posted by WILLIAMP
And then...???
No And then... I refuse to play your Chinese food mind games!
Old Apr 23, 2013 | 07:57 PM
sammyf's Avatar
And then... Take the device and rotate the 2 pieces to fit the gap at the appropriate spot (here's the rear measurement point):
Then remove and measure (133mm):
And repeat at the front location:
Old Apr 24, 2013 | 04:59 AM
heavychevy's Avatar
Did you level your surface or check to make sure it is level?
Old Apr 24, 2013 | 04:27 PM
WILLIAMP's Avatar
Understood.
Nice work!
Old Apr 24, 2013 | 05:22 PM
wross996TT's Avatar
So some sources of variation to consider:
Surface conditions (roughness, coplanarity)
Whether the device is perpendicular (perhaps add a level w/ a bubble)
Measurement error of the caliper (measure the distance several times at different positions).
Old Apr 24, 2013 | 10:58 PM
dubyaTT's Avatar
dubyaTT is a glorious beacon of lightdubyaTT is a glorious beacon of lightdubyaTT is a glorious beacon of lightdubyaTT is a glorious beacon of lightdubyaTT is a glorious beacon of light
Very nice work sir, that will get the job done.
Old Nov 13, 2013 | 07:54 AM
redrocket265's Avatar
redrocket265 is infamous around these parts
Why not just use an expandable pen magnet and a micrometer? Way, way, way easier.
Old Nov 13, 2013 | 09:18 AM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
also, consider is fuel tank full?
driver sitting in car?
Old Nov 13, 2013 | 08:53 PM
Steve Jarvis's Avatar
Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !
The biggest issue is this won't work if you're not running stock height tires.
What's important is for your control arm geometry to be correct relative to the chassis. A taller side wall tire will change your ride height measurement without actually changing your suspension geometry. I much prefer a measurement from the center of the wheel, to the fender lip, to understand the relationship of the suspension geometry versus the chassis without being effected by tire height.
Later, Steve
00aston
Dec 25, 2015 11:11 AM
Texas1
Sep 20, 2015 09:12 AM
Zmydust
Sep 10, 2015 12:31 PM
Taxthe1%
Sep 10, 2015 09:33 AM
