Lighter steering after rwd conversion
Old Jun 24, 2013 | 10:49 PM
nyc996x50's Avatar
nyc996x50 is infamous around these parts
Just had a complete rwd conversion done! One word.... awesome! The car is totally transformed! I had H&R street performance coilovers installed and I'm running 305/30r19 and 245/35r19 (steve k ny spec) michelin pilot supersports.
I was surprised that the steering felt lighter. It feels more direct but still feels kinda light. Makes me wonder if the power steering is overpowering now that I have less weight in the front. Can this be improved with a gt2 power steering unit?
Old Jun 24, 2013 | 11:05 PM
Saint Ari's Avatar
Saint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud of
I just had the draft shaft connecting the front to the transmission taken out, and yes, it does feel lighter.
I'm going to have the rest taken out soon.
Btw, what are you going to do in terms of alignment? I'm curious if should stay with the Turbo alignment or go with the GT2 alignment specs...
Also, I have ROW suspension ... not sure if that makes a lot of difference ..
Old Jun 24, 2013 | 11:38 PM
nyc996x50's Avatar
I was able to get within factory Turbo alignment with the H&R street coilovers at the highest possible setting (they run low!) I use my car as a every other weekend car and plan to one or two DE events a year. I don't need the extra negative camber and I wanted to prolong the life of the tires.
Old Jun 25, 2013 | 03:10 AM
Carbon's Avatar
Carbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond reputeCarbon has a reputation beyond repute
I've driven a 996 Carrera Cab and the steering was noticeably lighter than my Turbo. I'm unsure if there's any difference in steering hardware between AWD and RWD cars (besides that accumulator/slave setup difference that's tied in).
Old Jun 25, 2013 | 07:49 AM
Engine Guy's Avatar
Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !
Power steering pump is just fine the way it is and you will get used to the lighter steering really quickly. You just removed thousands of pounds of rotational inertia from the front end by removing just the drive shafts alone. Now throw on a really light set of wheels and then tell us how light it is.
Old Jun 25, 2013 | 08:52 AM
nyc996x50's Avatar
I think you're right! I drove the car again this morning to the body shop and I said to myself, "this isn't so bad." I still get lots of feedback from the steering, especially on imperfect roads. With that said, I'll take my steering over electric steering any day!
Old Jun 25, 2013 | 11:51 AM
rxbike's Avatar
rxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond reputerxbike has a reputation beyond repute
My Carrera 2 was so much lighter in steering in comparison to the TT. Turn in was much better too
Old Jun 25, 2013 | 12:03 PM
pwdrhound's Avatar
The power steering unit is the same part number on the TT as the GT2. If you want to get a heavier feel to the steering then get adjustable thrust arm bushings and have your shop dial in more caster...
Old Jun 25, 2013 | 12:31 PM
32krazy!'s Avatar
i thought the p/s for the gt2 was the same as a tiptronic p/s not a 6 speed. isnt that were the slave assist comes in that the gt2 doesnt have?
Old Jun 25, 2013 | 12:39 PM
nyc996x50's Avatar
Sounds interesting. I'll look into this. Thanks!
Old Jun 25, 2013 | 12:44 PM
f1crazydriver's Avatar
f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !
The light steering like a GT3 is very nice... I swapped out the front rotors I had up front on my turbo (350mm) that weight 28lbs each to 2pc rotors that weight 17.5 lbs each WOW same effect as you did. The steering input was felt instantly backing out of the garage.
When I also did the rears, and the chatter went away with my lwfw at low rpms...
Their is not better mod then making these cars lighter.
Old Jun 25, 2013 | 01:13 PM
pwdrhound's Avatar
I was referring to the power steering unit (rack) up front being the same. The engine driven power steering pump is the same on the tip as the GT2, the 6speed pump is different due to the coupler for the clutch accumulator.
PV=nRT.
Sep 9, 2022 06:06 PM
Feelgood MD
Mar 24, 2016 09:35 AM
Yellopeter
Cayenne
Oct 9, 2015 11:20 AM
simoncpw
Sep 8, 2015 10:55 PM
AM v12v
Sep 4, 2015 02:52 AM
