PSS9 Setup
Old Oct 8, 2005 | 08:59 AM
jayster's Avatar
jayster is infamous around these parts
PSS9 Setup
In response to "Dave"s question, and some issues stated pertaining to set up/performance of PSS9's (FVD's or otherwise) on 996tt's.....I thought I might share with you guys my experiences.
There is an installed height front and rear for these assemblies.
Front; 75mm to 95mm (+/- 10mm range) installed length as measured from the center of of the shock bolt to the top of the bottom spring perch. I set it at 85mm for initial install.
Rear; 205mm to 210mm(+/- 2.5mm range) installed length as measured from the center of the lower shock bolt to the top of the bottom spring perch. I set the rear at 205mm. Generally this will leave about a 1 degree rake to the front, which is great for weight transfer during braking or acceleration. At this time you can adjust the rake to your prefernces via the front adjustment window ( still @ +/- 10mm range). When done with this step I scale the car, and more often than not, the corner and cross weights are too close to even warrant an adjustment. So off for alignment it goes. Use the GT2 specs for everything except ride height, and you will be "in the ballpark".
Now comes the last and most difficult part, dialing in the shock settings to your preference, this is very subjective and varies from person to person, so this is where your patience will reward you.
Initial settings I reccomend are (F/R) 6/5, or 5/4 (1=firm, 9=soft)
one click softer for the front, initially. Drive it a bit, then with your intuition set it one notch F and R in the direction your inclined to go(harder or softer), drive it a bit, THEN, go 2 nothces in the opposite direction your inclined to go, drive it a bit, then you will have a decent concept of what you are trying to acheive, and a clue as how to do it.
If you need anymore than this let me know, Jay Putnam.
Old Oct 8, 2005 | 09:42 AM
wross996TT's Avatar
Nice write-up Jayster. I do believe there is a difference in FVD vs. others, but I still think your ideas are good. I ended up (so far) with 4/4 settings. Also I've noticeed the suspension has settled in quite nicely...love it!
Old Oct 8, 2005 | 04:10 PM
Cordonaviation's Avatar
Cordonaviation is a glorious beacon of lightCordonaviation is a glorious beacon of lightCordonaviation is a glorious beacon of lightCordonaviation is a glorious beacon of lightCordonaviation is a glorious beacon of lightCordonaviation is a glorious beacon of light
Thanks Jayster, im gettin my Pss9s installed Tuesday and this helps me out when they ask how i want the car setup.
Old Oct 8, 2005 | 04:21 PM
02barebones996's Avatar
02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute02barebones996 has a reputation beyond repute
u can always talk to 20c4s here int he board (lucent motors)(sponsor) they install alot of pss9's on p-cars.. they know their stuff they can help u with dialing in your system
Old Oct 8, 2005 | 04:47 PM
wross996TT's Avatar
Just hooked up with Arling at Lucent. Very nice studio. Four GT3s sitting there looking mighty fine. Nice to meet you Arling!!!
Old Oct 12, 2005 | 03:02 PM
silver's Avatar
silver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to all
Wross,
Try running 4 front 3 rear. It will remove a bit of understeer without feeling much firmer over bumps. Ive been told you do want the rear bit firmer.
Old Oct 12, 2005 | 06:05 PM
wross996TT's Avatar
That's how I like my women...oops PI. I'll give it a try, however I don't have any understeer. Thanks.
Old Oct 12, 2005 | 07:51 PM
20C4S's Avatar
wross,
it was nice meeting u as well!
Old Oct 12, 2005 | 09:00 PM
Dave's Avatar
Dave is a splendid one to beholdDave is a splendid one to beholdDave is a splendid one to beholdDave is a splendid one to beholdDave is a splendid one to beholdDave is a splendid one to beholdDave is a splendid one to behold
Jay,
I appreciate you spending soo much time on the phone the other day. It is good to know that you folks are genuinely interested in your product and how they are applied to our cars. I'll give your settings a try and provide you some feedback on a PM. Again, thanks.
Dave
Old Oct 13, 2005 | 06:59 PM
Acropora's Avatar
Acropora has a spectacular aura aboutAcropora has a spectacular aura about
If I could do it again I'd have gone Moton Clubsports.
wrs
Nov 17, 2016 06:53 AM
COBB Tuning
Jan 5, 2016 07:06 AM
shifter_
Sep 30, 2015 04:00 PM
PBass
Sep 29, 2015 10:28 AM
BauerR
Sep 28, 2015 11:36 AM
