How do I pin or welding coolant pipes on the 996TT
If I've gone to all of the trouble to get to the damned things I'm going to want to make sure as possible that things are solid. $150 worth of fittings compared to the pain of getting to it is a small price to pay honestly. I want those suckers solid in place and the hoses clamped good too so is probably replace a ton of them. Lots of while you're in there kinds of things to be done I fear
i replaced every rubber hose while i had the motor out. cost was minimal. once the motor is out the fittings and housings aren't hard to get to.
https://www.6speedonline.com/forums/...911tuning.html
https://www.6speedonline.com/forums/...p-motor-4.html Post #54
https://www.6speedonline.com/forums/...-needed-9.html #135
And my all time favorite. https://www.6speedonline.com/forums/...ngs-fix-3.html
I could do it now in less than a day.
BLKMGK for what it's worth I bought the kit when I had mine welded and my shop said return them and they welded the factory pieces in place. It was definitely worth it to me since when mine let go I was 2 hours from home and had been up for 19 hours. Don't waste the money for the kit and just have the ones from the factory welded in place.
Removing the housings attached to the fittings can be done with the motor in place. Partial engine drop, your decision whether to weld or pin at that point. I am doing it right now.....and yes several of the lines were loose and could be pulled out with little force.
Rick
Rick
heavychevy
Sep 1, 2015 05:19 PM
