DIY V1 Hardwire
Old Dec 17, 2005 | 11:02 AM
andyk79's Avatar
andyk79 is infamous around these parts
DIY V1 Hardwire
Hey guys i was just wondering if anyone has hardwired there V1 to their 996 TT. I don't want to pay an installer and would like to do it myself. Some help would be greatly appreciated.
Old Dec 17, 2005 | 12:11 PM
Itzkirb's Avatar
check my DIY in my sig
Old Dec 17, 2005 | 02:11 PM
andyk79's Avatar
Thanks for the help.
Old Dec 17, 2005 | 09:21 PM
andyk79's Avatar
Does anyone know how to hardwire it directly to the sun roofs power source.
Old Dec 17, 2005 | 09:25 PM
Itzkirb's Avatar
you can probably find that by doing a seach on this forum or Renntech.org
Old Dec 17, 2005 | 09:34 PM
Ruiner's Avatar
There has to be a power wire in there somewhere...
Let me know what you find. I am about to pick up a V1 and will wire it myself as well.
Old Dec 17, 2005 | 10:59 PM
FineProperty's Avatar
FineProperty is infamous around these parts
I tested every wire in the Sunroof and light supply. The issue that came up for me was how long power stayed active after the key was turned off. The lights didn't work because they're on a relay timer. The Sunroof power supply seemed to be a constant on run in to a circuit board. I had to run a wire to the fuse block to pick up one that shut down when the key was pulled out of the ignition.
Old Dec 18, 2005 | 09:29 AM
mikerosi's Avatar
mikerosi is a jewel in the roughmikerosi is a jewel in the roughmikerosi is a jewel in the rough
The sunroof wire that you`re looking for is the front left, in the 4 wire plug. Then ground other wire to torx screw on motor. The V1 switches off when you turn off the key.
Old Dec 18, 2005 | 10:56 AM
Ruiner's Avatar
Color?
Old Dec 18, 2005 | 05:29 PM
AIRjordan23's Avatar
AIRjordan23 is infamous around these parts
i hardwired a v1 today. if you remove the panel that holds the interior lights/sunroof switch, and look strait up, you will see a connector, as said 2 posts above, its the front left wire within in a 4 wire plug.
i tapped in to this wire, works perfectly fine. if the v1 is on, and you shut the car off and take the keys out, the v1 will shut off as well.
Old Dec 19, 2005 | 01:46 PM
andyk79's Avatar
Is it fairly easy taking off the panels. I have this fear that i might snap something and end up with a broken piece.
Old Dec 19, 2005 | 02:46 PM
andyk just take the black little covers off and find the 2 screws, unscrew and gentley pop the panel off. very easy.
Old Dec 21, 2005 | 04:32 PM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
Consider mounting the V1 low on the windshield...the lower the better in terms of laser detection.
Old Dec 21, 2005 | 05:12 PM
VoltesV's Avatar
VoltesV is infamous around these parts
Here's an interesting read from Mike Valentine regarding where to mount your detector...
clicky
Old Dec 21, 2005 | 05:50 PM
The "sunlight bounce" issue is a non-event...the driving environment is just way too dynamic. And I doubt there is a computer out there that can calculate the bounce angles encountered at any given moment. The front fenders and front trunk lid are curved creating VERY complex bounce patterns. The difference between the highest and lowest windshield mounting locations is about 9", so even if you could calculate a static moment in time "bounce" answer, one mounting location might be better than the other in that case, while five minutes later (the sun has moved) the other location may be better. There are three other considerations with regard to sunlight bounce that make it a non-issue...if the sun is behind you, if it's cloudy, or if the sun is down.
Mount the V1 where you want, but lower is better for laser detection.
therock88
Jul 14, 2018 11:22 PM
ECS Tuning - VW
Sep 30, 2015 03:11 PM
gliozzi
Bentley
Sep 28, 2015 03:27 PM
panas001
Sep 27, 2015 02:51 PM
NRoy7
Sep 19, 2015 06:59 AM
