Pressure test found a weird leak
Old May 20, 2016 | 02:22 PM
ghostofpain's Avatar
ghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to behold
Hi guys,
I logged my car the other day with a friend and the data we collected showed a weakend boost level. So i pressure tested my car. The only tiny hiss noise came from this hose(the left on). the hose seems not to be a part of the main pressure system.What does it do? I will replace the hose of course, but can that cause the little weakend boost pressure. The boost reaches 1.0 bar as it should but the logs show that its going down slightly.
Someone got that leak too?
Thx for hints and comments
Old May 20, 2016 | 02:24 PM
Another pic u see the hose better.
Old May 20, 2016 | 04:36 PM
The Pork Hunt's Avatar
The Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond reputeThe Pork Hunt has a reputation beyond repute
That venturi check valve is quite notorious for failing. I'd replace that for sure. Part number is 996 110 652 70.
Number 9 in the picture.
Old May 21, 2016 | 01:19 AM
Hi there,
Its actually the hise with number 6 which is hissing. Its connected to partnumber 9. Thats a pump...what ever it does....
Old May 21, 2016 | 01:33 AM
Oh, u think that pump nr9 is shot? Ok...i replace that.
Old May 21, 2016 | 12:24 PM
Any hints to get this thing out? Looks like removing the 3 clamps from the hoses leading to the pump and boom. Or any problems known? Some tricks necessary?
Thx in advance
Old May 22, 2016 | 12:18 PM
Guys i need a quick hint.
Nr. 21 is damaged i need to replace it. But I dont know which way to mount it. Which way the air flows? up or down?
Thx for hints.
Old May 22, 2016 | 12:19 PM
Ops...forgot the picture
Old May 22, 2016 | 12:35 PM
Jeanmarcboilard's Avatar
Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !
Thx for hints.
Air flows into the plenum. In that pic, the air flows down.
Old May 22, 2016 | 12:44 PM
Great thx alot.
Wildcat1212
Jul 24, 2024 06:23 PM
Gene G
Apr 15, 2016 10:47 PM
charlie1
Apr 12, 2016 10:35 AM
tromero
Apr 4, 2016 06:16 AM
OK51MON
Apr 2, 2016 12:45 PM
