Error Codes for 996TT X-50
Old Dec 12, 2021 | 05:31 PM
jcam's Avatar
jcam is a splendid one to beholdjcam is a splendid one to beholdjcam is a splendid one to beholdjcam is a splendid one to beholdjcam is a splendid one to beholdjcam is a splendid one to beholdjcam is a splendid one to behold
Has anyone here experienced the following error codes and know what that the fix is?
P0040
P0300
P0301
P0302
P0303
The car appears to be running very normal with the exception of the Check Engine light!
Any help would be appreciated.
Old Dec 12, 2021 | 09:31 PM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
suggests o2 sensor locations are incorrect...exhaust/o2 sensors out recently? what do fuel trims say?
Old Dec 12, 2021 | 10:02 PM
jcam's Avatar
The following has been replaced:
Air Circulation Valve
Air Shut Off Valve
Oxygen Sensor
Plugs
Ignition Coils
Cam Lift Sensor/Camshaft Actuator Sensor
One mechanic has suggested that it's valve lifters....the car has +240K miles on it and is my daily driver.
Old Dec 12, 2021 | 10:05 PM
993GT's Avatar
the p0040 suggests the o2 sensors are in the wrong spot in the exhaust, has it been checked the wideband is in the pre-cat spot?
bank1...same side as all the misfires, the flip-clip o2 should be turbo side, the 4 pin/'flat' connector on muffler side. bank 1 is driver side, connectors on left/driver side of airbox/engine mount area
Old Dec 12, 2021 | 10:07 PM
jcam's Avatar
Thanks and please see my message above in regards to what has been replaced thus far.
Not sure about "fuel trims", though when I randomly filled the car with Chevron, the check engine light came on less often. So taking things to an extreme conclusion, I filled the car up with 100 octane and the check engine light went off...though I'm told not to do that too often as it will ruin the catalytic converters.
Old Dec 12, 2021 | 10:09 PM
jcam's Avatar
Thanks, I'll check
Old Dec 12, 2021 | 10:11 PM
993GT's Avatar
could also be a wiring issue but simple things first...lifter failure on all of only bank 1 would be odd and not explain the o2 sensing issue..but would the misfires..but again odd 3 cylinders all on one side
Old Dec 14, 2021 | 08:27 AM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
All 3 indicates a cam issue to me. Something wrong with the wiring, actuator, or mechanism that controls the cam. A Durametric would help diagnose to see if it is doing the same thing as the other side. There was a thread a while back where someone had the mechanism on the sprocket all busted up internally.
Old Dec 14, 2021 | 12:57 PM
993GT's Avatar
Yup think could definitely be a top-end issue, but basics first 👍
Old Dec 14, 2021 | 04:34 PM
jpflip's Avatar
Al three cylinders on left bank have problem with valve lift....I suspect a broken cam lift solenoid bracket ... Look here : https://www.6speedonline.com/forums/...-brackets.html
Yyp
Sep 12, 2012 05:48 PM
dominik...
Jun 25, 2009 11:26 AM
shaunt
Jun 21, 2008 11:06 PM
foxworth
Jun 23, 2007 09:54 AM
