Thanks Protomotive!
Old Feb 3, 2007 | 01:46 PM
  #136
sharkster's Avatar
Originally Posted by MARKSKI
Tom,
I did but starting at 40 mph in 4th on gt35rs doesnt do... I tried.
I did it in 2 shifts in substandard temps and with the boost controller OFF...
meaning that it runs on spring alone... and they are .8 bard springs on TAIL 44 mm WGs...
mark
Mark, have you considered dropping down in size on the turbos? So what you're saying is without the shift in those runs and starting in 4th the turbos are too laggy that way, right? The supra guys have it way worse than you tho I like the GT30R turbos myself and I think that's the way CJV will end up going. Jamie's set up ought to be really fast this way!
Old Feb 3, 2007 | 01:49 PM
  #137
topgun's Avatar
topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !
[quote=OhioGT2]
Originally Posted by SMR
Correct you can, but they rarely work as well as an external BC at high boost levels. At least in the Supra community, no ones relies on the Motec or AEM to control boost when running 7's. For a street car, I'm sure it would work fine for lower boost levels.
But back to the point between relying on either a BC or a Flashloader, I personally see no difference? Both approaches require a manual 5 second mental and physical input from the driver if and when they change fuels. Every car I know that runs different boost levels for different conditions needs some type of manual input from the driver. Like Markski said, if you can't remember to turn the boost down in certain situations, you should be driving a stock car with a warranty
I dont disagree about the boost controller most High HP cars use them but at the same time when they switch boost levels they also switch there files for the high octane fuel! MOST of them anyway. that is the difference. I'm no mad scientist but, I've had plenty of high hp cars & always switched my files when i ran the KOOL AID & swicthed to high boost! ...tom
Old Feb 3, 2007 | 01:51 PM
  #138
iLLM3's Avatar
Alex i doubt Mark cares about starting in 4th WOT at 20mph or w/e lol!!
He has an INSANE redline, and more powerband starting at 4k to redline witht hose turbos (with insane power being made) then a regular turbo with hybrids revving to 7k, its all preference i guess!
Mark said his setup wasnt laggy, and i guess that is true in the ideal gear and at the mph, thing is even NA cars ina high gear feel laggy without the turbos ha, i think mark's setup is fine, and he sure is loving it, wait until you see what those turbo's can do
Old Feb 3, 2007 | 01:53 PM
  #139
Divexxtreme's Avatar
Originally Posted by topgun
Yes your correct, but Maybe Im wrong, it was agreed that it didin't matter How but the fastest time would count! Scott? Just currious because DMK had his fastest with no shifts....tom
The list will still be ranked from fastest to slowest, but I'm going to start posting the number of shifts next to each submission.
Old Feb 3, 2007 | 01:54 PM
  #140
sharkster's Avatar
Hehe no martin I never said 4th gear at 20mph.. **** a K16 car lags with that! I just meant doing the 60-130 is all I think we all get caught up in having big-*** turbos. For some reason I want them smaller... some things come best in small packadges
  #141
sharkster's Avatar
Poor Scott. Look what you started
Old Feb 3, 2007 | 01:59 PM
  #142
iLLM3's Avatar
Oops my bad, 40 mph Anyway as he mentioned, im sure anyone who hopped in his car or took it for a little spin would be pleasantly surprised in how it feels lag wise!
Old Feb 3, 2007 | 02:00 PM
  #143
LOL...I know, I know....
Old Feb 3, 2007 | 02:02 PM
  #144
Jean's Avatar
Jean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond repute
Topgun
I was really not referring to the willie measurement contest . When I pay for 600HP I want to know that I have them, and if I need to do a shiftless run to beat a 400HP car with 2 shifts, I might have bragging rights, but not a 600HP engine,and I would be seriously pissed off. I was just mentioning that a one shift, or shiftless run, is not real street driving conditions and cannot be compared to magazines (2 shifts) or each other, however as far as bragging rights on the forum or rankings etc.., certainly cool.
Old Feb 3, 2007 | 02:12 PM
  #145
iLLM3's Avatar
Originally Posted by Jean
Topgun
Well since i speculate so much, if one shift on the street proves to be faster to that 130 than an identical or similar car, even a faster or slower car you would race, why couldnt it be ideal if by the end you would be a second faster than your 2 shift?
Old Feb 3, 2007 | 02:26 PM
  #146
Jean's Avatar
ILLM3
If you are running side by side with another car that has quite similar HP, from say 50mph, and you start racing each other, you would certainly want to be in 3rd. (or second in a 996 maybe), otherwise if you start in 4th., the other car will jump ahead of you so far ahead that you will never catch him back, he won.
The time that it takes you to reach 60-130mph will not matter, he will be ahead of you anyway.
But again, for the sakes of the rankings, great, but if you are interested to know how honest your tuner is with his numbers and what you paid for, then you would compare apples to apples, or at least try to. It all depends what each one of us is after at the end of the day, no right or wrong answer.
Old Feb 3, 2007 | 02:29 PM
  #147
topgun's Avatar
Hey, We're all in it for a little education on different setups & how they compare in diff situations. Might as well have a little fun while we'er at it
All this is just a teaser, especially for me since my car is under the knife & the whether sucks anyway! All i have is the forum & the crack pipe .
Old Feb 3, 2007 | 02:32 PM
  #148
topgun's Avatar
It's all good! By the way with my old setup it was 3 shifts , Im still learning
Old Feb 3, 2007 | 02:58 PM
  #149
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
In general terms, I am still not sure what that shiftless run achieves, this is not the way you would drive it on the street, nor the way you would race someone from a rolling 20mph, nor the way magazines test the cars, basically you will never be using your car this way.
A 2 shift 6.4s 60-130mph is certainly much more relevant than a "no shift" run, and it includes almost a 1 second shift time in the 6.4s. That being said, out of curiosity, it might be fun to know.
It has little relevance to street driving... this 60-130 time,which was pushed hard by you is a time to be done in the fastest manner possible regardless of shifts. Some will do well with a 4th gear only pull, others will not. Mark has an amazing car, but it is not suited to this "paper" test. DMK does it with no shifts and you do it with a sequential box, neither is a streetable real world example, but it is what we have chosen to do. Kevin
Old Feb 3, 2007 | 03:13 PM
  #150
I made a mistake.. I used one shift....
40 mph roll on did not do well. at 40 mph Im at 2300 rpms...
mind you guys I did this at .8 bar only.... Im not sure what it will do at 1.5 bars without any shifts....
I have 2 cars with garrett GT35Rs and I love them....
I can always do some magic to my gt35rs... put in the 76 mm lightweight compressor.
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
