Thanks Protomotive!
Old Feb 3, 2007 | 03:16 AM
  #121
Divexxtreme's Avatar
Originally Posted by KPG
For a guy that doesnt put much stock in dyno sheets...you sure do have alot of them ....you are starting to sound like me, and we cant have that happen! Kevin
I'd be proud to sound like you any day. I take that as a compliment.
Old Feb 3, 2007 | 08:21 AM
  #122
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Originally Posted by Divexxtreme
I'd be proud to sound like you anyday. I take that as a compliment.
Shhhh......
Old Feb 3, 2007 | 08:34 AM
  #123
buddyg's Avatar
Originally Posted by MARKSKI
I have two cars, the P car and my Evo 8... both exactly the same greddy boost controller... I have never been in the WRONG boost setting....
All the high end cars running twin turbo set ups... from vipers to mustangs to Vettes.....they use a AEM standalone paired with a EBC... including all the JAP cars liek Supra, Skylines. etc.
When was the last time any of you put ur boxers on the wrong way?
I would bet that the above is more prone to happen then one sitting in HIGH boost instead of LOW....
most guys here spend 10 minutes warming up the car... then another 2 minutes cooling off the car... why then would any of us make a mistake of being in the wrong boost setting?
If you don't respect the motor and use appropriate fuel with boost YOU DO NOT DESERVE TO DRIVE THIS CAR NOR ANY OTHER TURBOCHARGED CAR.
I would not give this car with a EBC to a high school kid that's for sure....
just my opinion guys.... from experience.
markski
PS. Im not saying that this approach is superior to others... just different...
You can also blow your motor by downshifting from 5th to 2nd at high speed and there is nothing to stop you, so I agree with Markski.
Old Feb 3, 2007 | 08:38 AM
  #124
buddyg's Avatar
Alex,
I did 6.46 60 to 130 @ .8 bars( boost controller off) but I saw a.9 bar peak.
40 degree temp with not too much traction... 2 shifts....
I still have yet to start cranking up the boost.... but cant get traction in cold temps...
I want to do a 0 to 300 KM and 100 to 300 KM...
Once you raise the boost and assuming you can get good traction you should be will into the 5's!
Old Feb 3, 2007 | 10:17 AM
  #125
SMR's Avatar
SMR
SMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the rough
[quote=MARKSKI]I have two cars, the P car and my Evo 8... both exactly the same greddy boost controller... I have never been in the WRONG boost setting....
quote]
Not completly true, we can use a BC that the AEM,motec,autronic and etc controls, not a exernal one as you mean
Old Feb 3, 2007 | 12:20 PM
  #126
SMR,
I have seen many 1000 HP conversion cars from Supras to vipers... and for some reason they all if not most of them had a external Boost controller...
my friend Marco who ran mid8s in his supra(2 years ago) and drove it the night clubs with me has one for example... and he is on AEM.
my point was that that is one way of doing it not the ONLY way... IM by far not an expert in this Im only sharing what I have seen...
markski
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Feb 3, 2007 | 12:27 PM
  #127
OhioGT2's Avatar
OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !
[quote=SMR]
quote]
Correct you can, but they rarely work as well as an external BC at high boost levels. At least in the Supra community, no ones relies on the Motec or AEM to control boost when running 7's. For a street car, I'm sure it would work fine for lower boost levels.
But back to the point between relying on either a BC or a Flashloader, I personally see no difference? Both approaches require a manual 5 second mental and physical input from the driver if and when they change fuels. Every car I know that runs different boost levels for different conditions needs some type of manual input from the driver. Like Markski said, if you can't remember to turn the boost down in certain situations, you should be driving a stock car with a warranty
Old Feb 3, 2007 | 12:30 PM
  #128
topgun's Avatar
topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !topgun Is a GOD !
Mark that a great run congrats!! Have you tried it in 4th not shifting? that would be a nice comparison with DMK's machine! It should shave a few off your time. I would love to see 60-130 on Ohio GT2's also...tom
Old Feb 3, 2007 | 12:40 PM
  #129
Jean's Avatar
Jean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond repute
In general terms, I am still not sure what that shiftless run achieves, this is not the way you would drive it on the street, nor the way you would race someone from a rolling 20mph, nor the way magazines test the cars, basically you will never be using your car this way.
A 2 shift 6.4s 60-130mph is certainly much more relevant than a "no shift" run, and it includes almost a 1 second shift time in the 6.4s. That being said, out of curiosity, it might be fun to know.
Old Feb 3, 2007 | 12:46 PM
  #130
Tom,
I did but starting at 40 mph in 4th on gt35rs doesnt do... I tried.
I did it in 2 shifts in substandard temps and with the boost controller OFF...
meaning that it runs on spring alone... and they are .8 bard springs on TAIL 44 mm WGs...
mark
9.66
click to view
Old Feb 3, 2007 | 12:51 PM
  #131
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
Tom,
mark
Im sure it'll take off like a bat with 1.5bars on a nice day even with the 35r's.
Old Feb 3, 2007 | 12:53 PM
  #132
geetee's Avatar
Im sure it'll take off like a bat with 1.5bars on a nice day even with the 35r's. Hey even if it doesnt and you have to shift 3rd to 4th, Im sure it'll be faster than a no shift.
Old Feb 3, 2007 | 01:25 PM
  #133
SMR's Avatar
SMR
SMR,
markski
You are so right, there is alot of ways of doing it..Im just sugesting a few of them...Most customers i do like a external BC on the Japs turbo cars, but on the Porsche that have and super inteligent BC in the motronic i lke it to control things
Old Feb 3, 2007 | 01:27 PM
  #134
SMR's Avatar
SMR
[quote=OhioGT2]
I do this all the time and there is no problem with motec or other BC, same as extrenal BC... Using it in the EMS can give you some nice featers and there is alot more going on then dragracing, when thing should hold toghter for like 7 sec you can have and diffrent approch to things
Old Feb 3, 2007 | 01:40 PM
  #135
topgun's Avatar
Yes your correct, but Maybe Im wrong, it was agreed that it didin't matter How but the fastest time would count! Scott? Just currious because DMK had his fastest with no shifts....tom
