Thanks Protomotive!
The danger of ****ty gas is that in very high HP applications, ****ty gas can result in detonation which can cause your engine to go BOOM. Good tuners like Todd do everything they can (timing, A/F ratios etc.) to prevent detonation....but my worry is that even though I only use the top name brands of gas, you never know when you might get a crappy gallon.
Even if your AFR's & timing are good, when you run high boost the ECU has no control of the boost only timing to pull from! If you get bad gas. Another thing about EBC, when I had my 930 with a motec I had to reload another program to adjust to the new fuel (C16) ! Again My Ignorance with the 996TT! Do you guy's have to change programs or is it the same program for all fuels, if so then you would be running rich on low octane fuel & low boost. Asuming the car was tuned safely on high boost with race fuel!!
Originally Posted by WOODTSTER
With or without boost controller, doesn't the ECU pull timing anyway
if it senses bad gas??
MK
MK
besides, it's only $10-15k to fix the engine and it gives you a good excuse to upgrade the internals...
- chuck
From what I know.. Todd has a program written into the ECu that allows the EBC to work.... Not to mention he gets around the Throttle body from closing VIA a software and not Hardwired diodes... that's neat.
I always respect my motors and never get out of hand on crazy boost with bad gas..... I even have a AFR gauge in my car... that's how I protect my motor...
markski
markski
2001 996TT 3.6L and stock ECU
Kevin and SMR,
The ecu does not know what gas ur running( thats like most stand alone like AEM, autronik, etc)... It does know the boost though...
The whole trick is to have the car tuned for different boost levels with appropriate fuels...
If I may compare... the evoms set up has a flashloader( which I also used to have).... and it tells the car what file to run...
However that set up runs constant boost setting.... whereas the Proto u adjust on the go...
having an evo8 that runs 20 psi on pumps and 40 psi on C16 I can say that it does work very well....
Most other turbo cars( high HP liek supras,).... run the same way..
markski
markski
Yes i know all that, but i like the ide that the montronic run all features, i know what happens when you over boost, when a hose slips off and etc...
I run exaktly like you decribe on all Supran and all other cars i do, but the aftermarked system does often not have knock control like the motroic have...
I love protos work but i do no like a greddy BC in my 100 000 dollar porsche
it works well... and noone except todd can answer weather the car still has Knock control.. but from recalling what he said b4 it does...
markski
Question. Taking protomotive car for example because most use BC's. Lets say you have 93 oct in the car. Your boost level is set on high (1.5bar).
You are running WOT around town. How is the engine protected? Isnt there a limit to retard timing? Can the ECU recognize timing being retarded and adjust boost?
I just spent apprx. $80K on my tunning(I dont mind a EBC). I actually like it.
markski
markski
But if you are sure about the fuel, then the risk is alot lower, but if you let the motronic do everything you are more bulletproff..this is my opinion
If the high boost setting is made for a diffrent gas, race fuel for examlple
