Running lean..
Old Jun 3, 2009 | 02:16 AM
lintc0532's Avatar
lintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond reputelintc0532 has a reputation beyond repute
Running lean..
So cold here now,took my car to dyno again.
I used 105 octane and sport model.After 5000rpm the AFR going up quite lean...and boost showing 25psi...My car is EVT700 with no cats..How is this possiable?Last time I dynoed it before I got the newest EVT700 tune it was normal and not showing that much boost..Is this definitly not right?
Old Jun 3, 2009 | 04:46 AM
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
lintc0532,
I know this is out of topic but when you say newest EVT700 what do you mean? Are you using Proto VTGs or EVOMS?
Nothing to do with the topic, just curious?
Old Jun 3, 2009 | 06:01 AM
lintc0532's Avatar
I got twice evt700 tune.Last year around OCT when I finish the turbos I got the first tune.Then this march when I run cat-less I sent them the ECU for another tune.The second time's tune is much better than first.It showed 35awhp more than before but I ran in this lean problem..
My turbos are proto upgraded but other parts like exhuast/intercooler/tune is EVOMS.So ye,quite a special case lol...
Old Jun 3, 2009 | 06:11 AM
milou's Avatar
you gained 35awhp by removing the cats your car should be crazy fast, you guys with 700kits should upload some wild videos.
As soon as my car is ready i'll be uploading videos every day
Old Jun 3, 2009 | 06:24 AM
lintc0532's Avatar
Yes I wish to,just about to finish it and get everything done.First I need to make sure the performance is right...Keep working on it.Pain!
Old Jun 3, 2009 | 07:05 AM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
you are going to kill the turbos and motor if you are not careful. I would call Todd at EVO and ask how high they recommend boosting and the leanest safe AFR they tested. You may have some kind of problem with the diverters or have not reset your boost sensors yet in the new turbos.
Old Jun 3, 2009 | 08:25 AM
MBailey's Avatar
Can you post the data? How lean is it? You may hook up a Durametric, if you can get hold of one, to try to confirm findings.
Old Jun 3, 2009 | 10:44 AM
Evolution MotorSports's Avatar
Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !Evolution MotorSports Is a GOD !
The AFR should not go lean after 5000 RPMS. You may have blown the boost reference line that attached to the fuel pressure regulator. Please check this on the right hand side on the engine compartment towards the rear of the car. Also, check all of the vacuum lines for leaks and secire all of them with safety wire or slamm zip ties. Email me the dyno with AFR and boost plot so I can better help you and determine the cause.
Evolution MotorSports | www.evoms.com
EVOMSit - intelligent tuning |www.evomsit.com
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Home of the Worlds Fastest 997TT Porsche(s)
997TT Standing Mile = 234.6 MPH
997TT Standing 1/2 Mile = 217.09 MPH
Fastest 1/4 Mile = 9.29 @ 172.7 MPH
60-130 MPH Time = 3.28 Seconds
Old Jun 3, 2009 | 07:41 PM
lintc0532's Avatar
I forgot to bring the dyno sheet with me from the dyno shop.Will do this today and send you an email,thanks todd.
Old Jun 4, 2009 | 09:25 AM
taylorcoleman's Avatar
taylorcoleman has a reputation beyond reputetaylorcoleman has a reputation beyond reputetaylorcoleman has a reputation beyond reputetaylorcoleman has a reputation beyond reputetaylorcoleman has a reputation beyond reputetaylorcoleman has a reputation beyond reputetaylorcoleman has a reputation beyond reputetaylorcoleman has a reputation beyond reputetaylorcoleman has a reputation beyond reputetaylorcoleman has a reputation beyond reputetaylorcoleman has a reputation beyond repute
Anyone know of the closest 4wd dyno to Pittsburgh, PA
Old Jun 13, 2009 | 09:51 PM
MBailey's Avatar
Lintc,
Could you give us an update with what happened with your lean issue?
Thanks!
Mike
Old Jun 13, 2009 | 10:21 PM
lintc0532's Avatar
It is as todd said.The vacuum line on the fuel pressure regulator blown off.I have reconnected today and resetting the ECU.
Old Jun 14, 2009 | 07:12 AM
MBailey's Avatar
Glad its nothing serious!
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
BLKMGK
Sep 19, 2015 03:51 PM
Korntera
Sep 15, 2015 08:20 PM
captain Greg
Sep 6, 2015 04:14 AM
sleepy
Sep 4, 2015 11:59 AM
