Official 997.1TT weight loss thread
Old Feb 3, 2015 | 02:13 AM
  #76
porschecayenne92's Avatar
porschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant future
Originally Posted by elite1
Great info, where is the link? I'm very lazy.
https://www.6speedonline.com/forums/...urbo-list.html
pretty much what you can do to a 997.1
- Vorsteiner vrt carbon fiber body kit (10K)
-elimination of rear spoiler with a non movable
-pccb which weight 1/2 of the standard brakes , or some cheap drilled and slotted ones (5k used )
-Lightweight batttery ( cheap -30 lbs ) (200$)
-gt2 or gt3 seats if you want to keep airbag or recaro poleposition ( 7-10k for gt2 &gt3 seats or 4k for recaro)
-carbon fiber fender 4k
-carbon fiber roof 3k
-carbon fiber doors 5k
-carbon fiber hood 1k
-oz , adv1 or bbs FI ( the most lightweight unsprug weight reduction )
-lighweight suspension , control arms . ohlins I heard its the best (5k I am not sure)
-remove stuff from trunk ( cheap -50lbs)
-maybe light weight crankshaft and titanium rods
-3inch xpipe exhaust 3-5k
Old Feb 3, 2015 | 05:09 AM
  #77
-carbon fiber fender 4k (20-30lbs)
-carbon fiber roof 3k (20-60lbs if you eleminate roof )
-carbon fiber doors 5k (30 lbs or more ,depends on what you remove inside ex bose ,remove window elevator and replace the window with plexiglass)
-carbon fiber hood 1k (15-20 lbs)
-oz , adv1 or bbs FI with toyo r888 ,hoosier or nitto ( the most lightweight unsprug weight reduction ) (-20-30lbs )
-lighweight suspension , control arms . ohlins I heard its the best (5k I am not sure(5-10lbs))
-plexiglass rear window (-10lbs)
-elemintation of back seats and seat belts (add rollbar) and they will conpesate for each other.
-you can cut some bumper support or remove them (-30lbs or more ) but its super dangerous in case of crash
Old Feb 3, 2015 | 11:36 AM
  #78
Stock clutch, dual mass flywheel and pressure plate - 47lbs
ERP Triple Carbon with steel flywheel -28lbs
ERP Triple with aluminum flywheel - 22lbs
Savings of 20-25lbs rotational weight.
Another thing to consider is tires, some tires weigh more than others !
#TeamAIM
Old Feb 3, 2015 | 01:09 PM
  #79
ecpChris's Avatar
ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !
Great point, R888s are among the more heavy tires (generally 2-3lbs per tire heavier than most others). Other than the additional grip, I offset this by putting them on really lightweight OZ wheels.
Old Feb 3, 2015 | 10:12 PM
  #80
elite1's Avatar
elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !
Tires play a part for sure, next to rims.
I found the 996 thread to be interesting. They remove and weigh. 300lbs sounds great but, at what cost for the equivalent of 47HP? (thanks HeavyChevy.)
If I were to drag the car, this works, but, I like to track my car and, less weight to throw around in every corner make corner make this much easier when power to weight is irrelevant.
Old Feb 3, 2015 | 11:17 PM
  #81
pwdrhound's Avatar
You have 40lbs to loose to offset your roll at and harnesses going in. Seats should do that. It all adds up. After the upcoming diet my car is currently on I'll be at 3190 with fuel minus driver with a full interior car. Basically 300 lbs lighter than when I got the car. How heavy was your car when Chris had it on the scales? How much fuel was on board?
Old Feb 3, 2015 | 11:26 PM
  #82
elite1's Avatar
Car was 3,692 lbs. 130lbs driver weight. I think he got that perfect.
Harness Bar puts me over 3,7K, " wrong direction." I have lost the rear seats, belts, and woofer. Also a ton of insulation in the rear fenders.
I haven't weighed any of it though.
Old Feb 3, 2015 | 11:49 PM
  #83
pwdrhound's Avatar
3692 - 130 - 80 (alignment equipment) = 3482 (car w/ unknown amount of fuel)
Old Feb 3, 2015 | 11:53 PM
  #84
elite1's Avatar
No, 3692 included the fuel.
Old Feb 4, 2015 | 01:13 AM
  #85
pwdrhound's Avatar
Exactly.
Old Mar 13, 2015 | 03:19 PM
  #86
longboarder's Avatar
Bumping this thread as I just returned from BBI with some weight loss ideas.
I have two weight loss mods so far -
BBI stainless exhaust with 200 cel cats.
Ohlins coils with BBI dog bones+end links
Not sure how much weight this saved, maybe 25 pounds, however offsetting this is a fuel cell mounted in the trunk holding 3 gallons of meth nexessary to run 650+ wheel on the 997.2. The fuel cell plus lines, fittings, etc plus 3 gallons of fluid is well over 25 pounds so I'm pretty sure I've gained more weight than I have lost.
This thread has some good ideas for weight loss. For now I think I'm going to start with simple stuff:
OZ 19"s wheels
Recaro Sportster CS seats
Rear seat removal
These should net over 100 pounds of weight loss. Not sure how much the wheels weight vs the stock centerlocks, but the unsprung weight reduction will be nice. The Recaros and BBI bracket are about 25 pounds each vs stock adaptive sport seats which are nearly 70....so that's almost 100 pounds right there. The rear seat looks like about 20 pounds as well.
That should get me started. I don't want to do anything that is not easily reversible.
Any other quick and easy ideas?
Old Mar 13, 2015 | 03:47 PM
  #87
ecpChris's Avatar
Which OZ wheels? I have weight of our stock wheels in another thread
Old Mar 13, 2015 | 03:52 PM
  #88
For 19" it looks like the options are Ultraleggera or Formula HLT.
The Challenge 18" is probably lighter but I would like to stick with 19's.
Old Mar 13, 2015 | 04:22 PM
  #89
ecpChris's Avatar
On my phone so can't post it cleaner but here is a comparison of my OZ to stock
Old Mar 13, 2015 | 04:33 PM
  #90
Hmm the rears are about the same interesting. Which OZ's do you have?
