DME report
Old Mar 8, 2012 | 03:57 PM
mithiral67's Avatar
mithiral67 is a jewel in the roughmithiral67 is a jewel in the roughmithiral67 is a jewel in the rough
DME report
Ok, found the one I think, just have a very odd DME report, but the PPI came back clean. Can I assume that something was glitched on the DME when it recorded the overrev
Range 1 655
Range 2 55
Range 3 1
Range 4 1
Range 5 1
Range 6 1 - 42 hours.
Old Mar 8, 2012 | 11:32 PM
sparkhill's Avatar
sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !
It is fine.
Old Mar 9, 2012 | 01:07 AM
VID997's Avatar
VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !
Old Mar 9, 2012 | 07:59 AM
eurotom's Avatar
eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !
Some may say it's fine others will say move on and a find a clean car. Either way good luck
Old Mar 12, 2012 | 01:35 AM
mikegr's Avatar
mikegr is infamous around these parts
What is the meaning of DME report since there is a rev limiter?
Old Mar 12, 2012 | 11:37 AM
sparkhill's Avatar
The rev limiter can't prevent a bad down shift and might not be able to catch a quick over-rev if the car is either in neutral or the clutch is engaged. Other might be able to comment on the validity of the second part of my statement.
Old Mar 12, 2012 | 12:06 PM
arash's Avatar
arash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to behold
I'd call this "livable". There's probably no damage to the engine, but if you're real picky, there are cleaner cars out there.
Old Mar 16, 2012 | 02:15 PM
mithiral67's Avatar
That one sold before I could look at it.
found an 09 with 1k ignitions in range 1 and 25 in range 2. She was driven gently.
Old Mar 16, 2012 | 05:52 PM
quick's Avatar
quick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant future
I am sure people would still say why buy this when MANY cars with ZERO over revs are still out there
Old Mar 18, 2012 | 01:54 PM
aamersa's Avatar
aamersa is a splendid one to beholdaamersa is a splendid one to beholdaamersa is a splendid one to beholdaamersa is a splendid one to beholdaamersa is a splendid one to beholdaamersa is a splendid one to beholdaamersa is a splendid one to behold
Does that mean that in a pdk car it's hard to damage the engine despite high rev driving?
Old Mar 18, 2012 | 02:00 PM
arash's Avatar
Yes, as far as I know, the PDK will not let you downshift into a lower gear if that will put you outside the redline. I haven't tried or tested this, but you might still be able to get stage 1-2 over revs while accelerating if you hit the redline really hard.
--arash
Old Apr 23, 2012 | 10:32 AM
mithiral67's Avatar
Found a 997.1 with 95% of the options I want and with a fabspeed tune and exhaust (and HRE rims), but the ecu report obviously has a lot of over revs from the raised limiter.
Based on miles and options, they are asking about $3-5k over market to consider the options.
Thoughts?
Overrevs:
Range 1 - 13362 578
Range 2 - 3284 578
Range 3 - 625 359.9
Range 4 - 121 359.9
Range 5 1 220.8
Current Hours 578.6
Old Apr 23, 2012 | 11:09 AM
nevert00fast's Avatar
nevert00fast is infamous around these partsnevert00fast is infamous around these parts
If it has a tune with a raised rev limiter, it's normal.
I have a tune with the stock rev limiter and still got minimal range 4 over revs FWIW.
Old Apr 23, 2012 | 07:29 PM
Abby997TT's Avatar
Abby997TT has a spectacular aura aboutAbby997TT has a spectacular aura aboutAbby997TT has a spectacular aura about
nothing really to worry about.
Old Apr 23, 2012 | 07:31 PM
mithiral67's Avatar
What type of issues getting an aftermarket warraty would I have?
