PSM failure help!!
Old Aug 4, 2012 | 02:22 PM
PAULG's Avatar
PAULG is just really nicePAULG is just really nicePAULG is just really nicePAULG is just really nicePAULG is just really nice
Unhappy PSM failure help!!
Today when I was going to turn the car left very slowly on the street my steering wheel was turning very hard and the light of PSM failure appear ,I stop the car and restart it quickly again because I was in the middle of the road,the light disappear and I went to my home without problem,can anybody tell me what is this??it is a problem ?
If it happened when I have more spead?
Old Aug 4, 2012 | 02:52 PM
svoshop's Avatar
svoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond repute
The stability program saw a fault and turned the system off.... Giving you the error on the dash. Restarting the car let the system restart and the car did not see the fault a second time.
From the symptom and context of where you were and how you were driving, I would suspect a wheel speed sensor or something along those lines.
A scan should show the codes needed to diagnose further.
Mike
Old Aug 4, 2012 | 02:54 PM
sparkhill's Avatar
sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !
It is probably nothing. If the light went away and does not return, I would not worry about it. That sort of thing happens from time to time.
Old Aug 5, 2012 | 07:15 AM
PAULG's Avatar
Thanks for the help guys !
Today I turn on the car and one more message came out,Add air showing the back of the driver wheel,I put air in the wheel and no message now,
Is this relate it with PSM failure??
Any opinions ??
Old Aug 5, 2012 | 07:59 AM
svoshop's Avatar
I would not assume they are related. If it comes back have it inspected, just keep in mind that when the Psm failure is present you will not have the nannies to keep you in line if needed.
Old Aug 5, 2012 | 08:14 AM
PAULG's Avatar
The only think that I am concerning is before 2 seconds from PSM failure the steering wheel was moving like the engine was off.
Thanks for the help!
Old Aug 5, 2012 | 12:45 PM
svoshop's Avatar
I know we have some variable assist power steering, but I do not know why you would lose all power assist and make the steering feel manual...
If you are concerned, I would have the car put on the DME. There are several systems in the car that should have stored some fault codes. This is what the technicians ( or you ) will need to pursue the problem and lead to a fix.
Mike
Old Aug 8, 2012 | 02:45 PM
Emre@Esmotor's Avatar
Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !
Hello Paul,
Do you have aftermarket coilovers or sway bars?
Cheers,
Emre
Old Aug 8, 2012 | 09:54 PM
PAULG's Avatar
Originally Posted by Emre@Esmotor
Hello Paul,
Cheers,
Emre
Hi Emre!
No,but the only think that I remember 3 weeks before I had tire because one screw was on the Back of the wheel and I put off to fix it.
It related this?
Old Aug 9, 2012 | 02:02 AM
Check your steering pump oil. and re-calibrate the steering angle sensor with PIWIS when you go to the dealer.
That may solve your issue.
Old Aug 9, 2012 | 02:53 AM
CharlotteGould's Avatar
CharlotteGould is infamous around these parts
bumb ubm!
pwdrhound
Sep 13, 2016 10:44 AM
randalldahme
Feb 19, 2016 03:56 PM
DYL 911
Oct 1, 2015 02:47 PM
PelicanParts.com
Sep 25, 2015 03:17 PM
ophtho
Sep 18, 2015 03:00 PM
