Light weight Roof
Old Mar 17, 2014 | 06:30 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
Light weight Roof
Am looking for good quality light weight roof for my car
As am trying to make it lighter .. I heard i can reduce 50lb which i think its good deal !
So What options i have ??
I email gettydesign.com
They have the most worst customer service i have ever
Saw !!!! So is there is another brand ?
Thanks in advance .. !
Old Mar 17, 2014 | 04:57 PM
tt91185's Avatar
tt91185 is infamous around these parts
http://www.racperformance.com/index....MGAerodynamics
It's only about a 25lb in weight savings. If it were me I would just add more power.
Old Mar 17, 2014 | 08:46 PM
pwdrhound's Avatar
The 50lb savings is a myth. I replaced the sunroof on my car with a solid roof and headliner from a GT2. I weighed everything going in and out and the total savings is 27lbs. The important part is the fact that it is weight coming off the highest point on the car. Using a carbon roof panel will save another 8lbs over the OEM solid roof (17lbs vs. 9lbs). I track my car and did not want a carbon roof shattering into sharp splinters in case of a rollonver so it was a no go for me. The solid OEM roof panel is only about $500 and about the same for an alcantara headliner if you can find a used one. I bought one in perfect condition on ebay for $450. Labor will be about $2000 and you will have to replace the windshield during the process so add another $500 for an OEM windhield. Total conversion cost using OEM parts will be right at $4000. Another less obvious benefit to the solid roof is the fact that you will gain about 1" of headroom which comes in handy when wearing a helmet.
Old Mar 18, 2014 | 12:06 AM
Shibeeb's Avatar
Shibeeb has a spectacular aura aboutShibeeb has a spectacular aura aboutShibeeb has a spectacular aura about
Shipping would cost you a lot because you're in Kuwait, adding more power would be easier for you, and more fun heheh
Old Mar 18, 2014 | 05:36 AM
ysfg35's Avatar
Well am still confuse about getting a carbon roof or just light weight , some told me , very light roof will make noise inside the car .. So it will be bad idea , as am driving the car AS daily drive ..
I just want to remove all the weight up the car and save 50lb !!
Old Mar 18, 2014 | 08:38 AM
pwdrhound's Avatar
I guess I'll say it again. It is physically impossible to save 50lbs via a solid roof conversion. Keep dreaming. Read my post above. The factory solid roof is welded to the car. You will not get any noise if done properly. The carbon roof is glued to the car and I would only do it if the car had a full roll cage built in and the driver was wearing a helmet. That's just me.
Old Mar 18, 2014 | 08:46 AM
ysfg35's Avatar
i got your point.
Old Mar 18, 2014 | 09:29 AM
tt91185's Avatar
A metal roof is simply a thin skin (1/16"?) and once it's torn, buckled, etc, there is no strength remaining anyway. I would assume the structural components under either skin are nearly identical. Along with the rest of the chassis, that is where strength in a serious accident comes from.
Cars are designed to crumple upon impact of a relatively large object. A high speed side impact with something that is not a relatively large object, a tree in this case, does not provide enough surface area for the components to crumple as designed. It has nothing to do with the material of the roof skin.
Old Mar 18, 2014 | 03:01 PM
greekc6's Avatar
Subscribing
Old Mar 19, 2014 | 01:58 PM
ysfg35's Avatar
i just PMed GMG waiting for reply.
Old Mar 19, 2014 | 04:56 PM
tt91185's Avatar
Let us know how it goes I'm a bit interested as I'm building a track car.
Old Mar 20, 2014 | 08:37 AM
mikestyle's Avatar
mikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud of
If you pay 4k for 25 pounds savings... you better be really skinny
Old Mar 20, 2014 | 11:19 AM
ysfg35's Avatar
do not worry about my weight , just worry about your style.
Old Mar 20, 2014 | 09:58 PM
pwdrhound's Avatar
YSFG35, got your PM. Here is the link detailing the sunroof delete mod I did last year.
https://www.6speedonline.com/forums/...elete-mod.html
This should answer most of your questions. Prices are in the thread. I ended up not purchasing a new headliner as I found an alcantara one on ebay from a wrecked GT2. It was in mint condition and cost me $450 shipped.
J9277655
Dec 28, 2015 11:01 PM
Sales@RSW
Sep 3, 2015 09:34 AM
GSR Autosport
Aug 26, 2015 05:20 PM
TrackOne
Aug 20, 2015 12:56 PM
