A pillar cover removal
Old Aug 5, 2015 | 08:45 PM
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
Hi there,
I am looking to run a microphone cable and radar detector power wire down the A pillar to the fuse box. I searched for information on removing the cover but couldn't find definitive guides for a 2008 cab.
Do you just pull on the cover to release the metal clips? Or is there another way to do this? Wanted to make sure that I don't pull too hard before I hear the crack of the cover!
Old Aug 6, 2015 | 04:40 AM
xbox_fan's Avatar
xbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond repute
Also interested of this...
Old Aug 6, 2015 | 05:20 AM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
Jako...it does pop out and up....check out post #2.
HERE
Or post #32 HERE
Good luck,
DC
Old Aug 6, 2015 | 08:23 AM
Jako's Avatar
Thanks Rock. I've seen the #2 post but not the #32nd. Although they're coupes the same principle apply for the verts. Knew I could count on you. Thanks
Old Aug 6, 2015 | 05:14 PM
therock88's Avatar
No problem...Good luck....
DC
Old Aug 8, 2015 | 01:08 PM
coquitlam1's Avatar
coquitlam1 is a glorious beacon of lightcoquitlam1 is a glorious beacon of lightcoquitlam1 is a glorious beacon of lightcoquitlam1 is a glorious beacon of lightcoquitlam1 is a glorious beacon of lightcoquitlam1 is a glorious beacon of light
Jako, are you installing Bluetooth device? which one you are installing? Dension?
have you ever consider install microphone in OEC location with OEM microphone? I have read someone install mike in the OEM location with OEM's and with aftermarket's.
Old Aug 9, 2015 | 01:09 AM
Jako's Avatar
Hey. I've already installed the Denison BT500s. It's a good system. I was wanting to put the mic at the top of the headliner. Didn't think of putting it or splicing into the factory microphone. Do you have the DIY for this mod?
Old Aug 9, 2015 | 02:22 AM
coquitlam1's Avatar
I remembered I saw someone talked about install OEM microphone on the steering column, but I am not sure if it can be used for Dension. what I understand is the OEC microphones has 2 pieces and not too expensive. if it is can be used for Dension, it will be better for OEM look.
Does anyone know about it?
PV=nRT.
Sep 9, 2022 06:06 PM
NIKAS
Aug 20, 2019 07:53 PM
Jul 29, 2019 11:13 AM
Fester
Sep 8, 2015 09:35 AM
gulf gt
Aug 27, 2015 10:27 AM
