Steering wheel swap from 991.2TT to 997
Old Oct 21, 2018 | 09:11 AM
  #151
myw's Avatar
myw
myw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to behold
annoyingly, the one module the durmetric pro cannot access or code is the steering wheel module - you will need a piwis II
Originally Posted by nzskater
Wish I'd known that beforehand although that contradicts everything I've read previously.
Anyone able to Code their Steering Column using Durametric Pro? Mine generates an error when trying to connect. Unsure if it's due to it looking for a different module or a fault with the module itself.
Old Oct 21, 2018 | 12:43 PM
  #152
nzskater's Avatar
nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !
Went into my local Porsche service centre and they had it working in 5 minutes. They ignored the error and coded multi function back in and all buttons are now working. Install success! Thanks shadow993 and random Lithuanian guy who sold me the wheel and airbag off eBay
Old Dec 3, 2018 | 04:21 PM
  #153
itzjere's Avatar
itzjere is infamous around these parts
Thanks to this thread, and the huge guidance that shadow993 provided, I completed this swap today.
For tiptronic users thinking about doing this mod - I highly recommend it. There is something unnatural about shifting gears on the toggle buttons. After installing the 991.2 steering wheel, the PDK paddles feels much more proper and natural (I had a SMG M3 before).
Something else I have noticed, and maybe other tiptronic converted users can add, is that the shift response is better. Something about the updated steering module, better feedback from the paddles (original toggle buttons felt mushy) and maybe even updated steering module software makes the shift response better. I'm not going to even compare this to an actual PDK gearbox because there is none, but the overall driving experience has been much improved with this wheel. I highly recommend for tiptronic users.
Old Jan 16, 2019 | 09:20 PM
  #154
gnoy26's Avatar
gnoy26 is infamous around these parts
hi guys,
i have a 2007 997 turbo tipp, it had the triangle air bag with multifunction, i have upgraded to the 997.2 sport pedal steering with module done a few years back.
now i plan on upgrading to the 991.2 steering with pedals for the throw. would i need a new module? i dont care about the multifunctions tbh
Old Jan 16, 2019 | 09:38 PM
  #155
shadow993's Avatar
shadow993 is infamous around these parts
No...
Old Jan 16, 2019 | 09:39 PM
  #156
shadow993's Avatar
Originally Posted by gnoy26
hi guys,
No... not at all. You can buy a module for the MF to work or you can buy blanks at suncoast to eliminate
Old Jan 24, 2019 | 07:45 AM
  #157
jayi836's Avatar
jayi836 is infamous around these partsjayi836 is infamous around these parts
Just did my '08 997TT after reading here and Jim Wongs video,thanks everyone.
Paddles removed, shroud replaced. need to order the GPS and 997.2 modules for the controls to function.
No illumination on the wheel at this time not sure if this comes with installing the 997.2 module?
Old Jan 24, 2019 | 12:14 PM
  #158
nzskater's Avatar
Illumination worked for me after installing both the module and the GPS adapter, I *think* it requires both.
Old Jan 24, 2019 | 12:26 PM
  #159
jayi836's Avatar
Thanks seems I have to power the Macan module with the GPS adapter.
Now I'm confused on what 997 module is needed,.one is a PDK and the other is manual transmission. Everything I read states to get the 997-613-289-01. Sent an email to Paul Li to confirm.
Old Jan 24, 2019 | 03:00 PM
  #160
jayi836's Avatar
Response from Paul Li.
Just 997.613.289.01 can fits 997.1 to support multifunction and shifts peddles,in your case is manual,so just need fits multifunction. Replace steering control module and coding following this guide
https://gpsadapter.us/blogs/installa...e-coding-guide
Remember setp 3,check set "Automatic (Tiptronic/PDK)" and "PDK" (both!) to "installed". even manual car.
BTW: please check current steering control module parts number equipped,your 997.1 is very late version,some this 997.1 original equipped
997.613.289.00 or 997.613.289.01 (either will work)
The numbers in bold is from his second email confirming both 997 modules will work. He also has this information in his manual.
Old Feb 1, 2019 | 03:18 PM
  #161
jayi836's Avatar
Anyone in SoCal have a PIWIS2?, will pay for an hour of your time, need to get the 997-613-289-01- steering control module programmed. would rather pay a fellow enthusiast than dealer.
Old Feb 18, 2019 | 11:21 AM
  #162
jayi836's Avatar
Illumination and controls only worked for me until programming was done by a friend and his PIWIS 2, bit of a challenge as Rusnak Porsche refused the job.
Old Jun 19, 2019 | 09:11 AM
  #163
997TurboTom's Avatar
997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !997TurboTom Is a GOD !
so 997.1 manual with NO multifunction - upgrading to a 991.2 with multifunction
I need just one module? 99761328901?
Old Jun 19, 2019 | 09:42 AM
  #164
jayi836's Avatar
yes, watch Jim Wong's 2 part video makes it very simple.
Old Jun 19, 2019 | 01:32 PM
  #165
this one?
he makes conflicting statements. Says you need both the oem module AND the STMV1/STMV1-H adapter, but video description says you only need one adapter
