UPDATED: Process for 997 multifunction wheel swap / steering wheel removal
Old Nov 5, 2012 | 12:00 PM
  #106
AJG's Avatar
AJG
AJG is infamous around these parts
very nice steering DrVolkl
Old Nov 5, 2012 | 05:00 PM
  #107
Z00mie's Avatar
Z00mie is infamous around these parts
If anyone needs the multi function buttons/wheel from a Manual Trans,triangular airbag 2006 911C2S in Stone grey to do this mod I have a spare (it has 43K miles on it)! Let me know...
Old Nov 14, 2012 | 04:04 PM
  #108
Gibbo205's Avatar
Gibbo205 is a jewel in the roughGibbo205 is a jewel in the roughGibbo205 is a jewel in the rough
Hi there
Anyone got any pics of what your pushing at the rear to release the airbag?
When re-installing the wheel will it go back on straight without issue or does it need some adjusting to keep it all straight?
Old Nov 14, 2012 | 07:34 PM
  #109
Z00mie's Avatar
Gibbo,
Sorry dude, I'm not at home or I would take photos to help. Inside the wheel is a piece of spring steel. This spring steel is roughly triangular shaped in the wheel. When you push thru the access hole it displaces the triangular shaped steel enough for some plastic hooks to disengage from the airbag thus releasing it. The reason for this monkey motion is that by pushing in one place it disengages multiple (3 I think) hooked points simultaneously. When reinstalling insure it is reasonably aligned and apply uniform pressure on the bag towards the hub and it snaps back in. It is sort of keyed to fit back only one way. No alignment necessary. Sorry for the crappy explanation....
Old Nov 15, 2012 | 08:09 AM
  #110
BLKPPR's Avatar
BLKPPR is infamous around these parts
I just put my wheel on. It took 15 minutes and I did it at night. 10 of that was waiting the requisite 10 minutes. T-55 works perfect
Old Nov 15, 2012 | 01:57 PM
  #111
Gibbo205's Avatar
Can you show me a pic of the tool you used to remove the airbag please?
Old Nov 15, 2012 | 02:00 PM
  #112
DrVolkl's Avatar
DrVolkl has a brilliant futureDrVolkl has a brilliant futureDrVolkl has a brilliant futureDrVolkl has a brilliant futureDrVolkl has a brilliant futureDrVolkl has a brilliant futureDrVolkl has a brilliant futureDrVolkl has a brilliant futureDrVolkl has a brilliant futureDrVolkl has a brilliant futureDrVolkl has a brilliant future
Use a thin alan wrench... whatever fits. Push hard, it compresses the ring spring, then it all pops out.
Old Nov 15, 2012 | 07:51 PM
  #113
BLKPPR's Avatar
volk is right any small diameter allen wrench pushed up will work. Super easy to do
Old Nov 16, 2012 | 05:20 AM
  #114
BLKPPR's Avatar
This by the way may be the easiest mod you will ever do on your car. I mean easier than side marker lights. Only thing easier may be putting a license frame over your plate.
Old Nov 30, 2012 | 06:01 PM
  #115
keninirvine's Avatar
keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !
I'm preparing to install a new DCT wheel to replace my factory MF wheel. I've removed the air bag and center air bag retainer bracket. I haven't yet removed the wheel, but when trying to remove the trim with the MF buttons, I wasn't sure how to pull them off after removing the retaining screw for each. Also, what holdS the control module in place, as mine seems to be fixed to the wheel and I don't know how to remove it in case it needs to be transferred to the new wheel when it arrives tomorrow.
Folow-up: I did get my trim pieces removed today without any problems, and expect that the module will not be an issue either.
Final Follow-up: I finished the job with no problems at all. The new wheel looks fantastic.
Old Dec 12, 2012 | 03:57 PM
  #116
Stroker's Avatar
Stroker is infamous around these parts
Hi guys, i am David from germany and have a question.
Thanks a lot for you support in advance.
I have a 997 2007 TechArt Turbo with a MF steering wheel.
At the moment i am redesigning the car to the FL version.
So, i also would like to change the steering wheel to the round
one from the FL model.
Could you tell me if this is possible or not and if it is possible
is it only changing and coding or is it much more difficult maybe.
Regards
David
Old May 28, 2013 | 06:22 PM
  #117
zerodude's Avatar
zerodude is infamous around these parts
Still have wheel? Does it have the electronics intact? Interested in selling?
Let me know please.
Old May 29, 2013 | 04:08 AM
  #118
Z00mie's Avatar
Yes, I still have it and it does have the multifunction switches etc. It's for a manual trans car...
Old Jul 7, 2013 | 09:06 AM
  #119
harold_callahan's Avatar
harold_callahan is infamous around these parts
Not Trying to Hi-Jack the Thread, but I am about to try this on a 987.2 (2009 Boxster S). I am going to replace the stock STD wheel with the MF wheel. My dealer want 3 Hours labor to do the job ($390).
I am hoping that the wiring harness is already there...
I'll let you know how I make out. But any advice is welcome.
This is the wheel I am installing.
-Callahan-
Old Jul 7, 2013 | 09:34 AM
  #120
PasPar2's Avatar
PasPar2 is a name known to allPasPar2 is a name known to allPasPar2 is a name known to allPasPar2 is a name known to allPasPar2 is a name known to allPasPar2 is a name known to all
Went from a normal PDK to a paddle shifter pdk wheel using these instructions. it was cake... and i am not very car handy
You have already rated this thread Rating: Thread Rating: 1 votes, 2.00 average.
