Multi-function wheel upgrade for 997.2
Old Nov 2, 2013 | 12:08 PM
  #151
997Dr's Avatar
997Dr is infamous around these parts
So I got a great alcantara wheel and shift boot/**** from dct motorsports and the multifunction upgrade from suncoast. I'm having the same problem others have had with the horn sitting too deep/flush and I can't seem to figure out what Kaz and others are talking about with regard to the spring.
Any help?
Old Apr 8, 2015 | 06:52 AM
  #152
monster1's Avatar
monster1 is infamous around these parts
A bit of a thread resurrection here!
I am attempting to fit a 997.2 steering wheel onto my 997.1 - I have a multifunction wheel and appropriate airbag and I am just trying to understand how it all goes together before I attempt the fit onto the car.
When I slide the airbag into the wheel, it locates as it should within the wire frame which springs back around the lugs to secure the airbag, and the two springs are in place and exerting some pressure on the underside of the airbag unit.
What is concerning me is that when I press the airbag as if to activate the horn, the airbag is stiff to push and then will not return easily back into place afterwards. Its almost as if the two springs under the airbag are not powerful enough to return it to position.
I have ensured the little wiring loom is sitting in its groove and I don't think anything is fouling!
Does anyone have any ideas? or could anyone explain how the horn is supposed to work on this type of steering wheel?
thanks
Old Apr 8, 2015 | 11:04 AM
  #153
monster1's Avatar
Originally Posted by chjkchj
How funny, I just ordered the same thing from Ryan at Suncoast and it is arriving tomorrow. I guess you go first and I can't wait to see your result.
Ha, coincidence! - your in the Uk and you thought it worthwhile ordering from the US? - I got mine from local OPC here in UK.
Old Apr 10, 2015 | 07:20 AM
  #154
monster1's Avatar
Ok, Ive fitted the wheel and although the horn works, the multifunction controls are not working. Ive just placed an order for the later control unit, see if that does the trick!
Old Feb 24, 2018 | 09:27 PM
  #155
Kevin_86's Avatar
Kevin_86 is infamous around these parts
Anyone happen to have there non multifunction wheel center trim piece laying around they would like to sell?
Thanks,
Kevin
Old Feb 27, 2018 | 10:36 AM
  #156
myw's Avatar
myw
myw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to beholdmyw is a splendid one to behold
Thanks,
Kevin
i have a full heated 997.2 black wheel with grey trim piece that i was going to list in spring for 300$. to find just the trim piece itself is very VERY rare imo based on the years i have been on the forums.
Old Feb 27, 2018 | 01:36 PM
  #157
myw's Avatar
myw
also 6 spd or pdk?
Thanks,
Kevin
PenguiN
Apr 22, 2021 07:33 PM
COBB Tuning
Nov 9, 2015 08:02 PM
vbb
Aug 21, 2015 10:17 PM
Aug 21, 2015 09:56 AM
JMon
Aug 21, 2015 08:20 AM
