possible Gearbox/Clutch problem
Old Mar 19, 2010 | 05:07 PM
geestyleed's Avatar
geestyleed is infamous around these parts
Thumbs down possible Gearbox/Clutch problem
Hi guys,
I have probably a problem with my gearbox. Mostly with the first two gears. Perhaps it is my inability to drive a manual, but I had serval manuals car before and I have never noticed such rough gear changes there.
Occuring problems:
1.) Shifting from the first to the second gear is bumpy and sometimes it makes the cracking sound as if you dont press the clutch.
2.) In the Stop and go traffic it is often difficult to get the first gear while rolling or standing. Only when I tries other gears before, the first one works properly.
3.) Shifting back from thrid to second is also sometimes bumpy, but not as bad as first to second.
These problems occur with cold and warm gearbox. I dont have these problem always, but pretty often and it just doesnt feel right....Shifting from the second to the third(and all the other gears) is no problem.
The car has 23.000 mls and it is a standard 2005 Carrera. No short shifter or other engine mods.
I will make another test drive tomorrow to make sure that it is not just me or my imagination...
Does anybody else had or has this problem?
I hope at least this is covered by the "awesome" Certified Warranty....
Thanks guys,
gee
Old Mar 19, 2010 | 06:18 PM
utkinpol's Avatar
utkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond repute
Originally Posted by geestyleed
Hi guys,
Occuring problems:
Thanks guys,
gee
I have certain feeling you did not get accustomed with your car yet. For how long do you drive it? Give it 3-4 months at least and you will get used to gearbox.
As of engaging 1st gear while rolling - well, it seems to be a common problem. you can try to escalate to dealership but it is easier to push into 2nd gear and then into 1st when you need to engage 1st gear. For me it works like a charm this way - second then first. When clutch pedal is all the way down you should not hear any noises.
Not sure what you mean by 'bumpy' but get it some time, if you have faulty syncros it will show up very soon.
Old May 6, 2015 | 06:45 PM
zegm's Avatar
zegm is infamous around these parts
Second gear shifting not feeling right
We just picked up a 2007 Carrera for my wife. It has 66k miles and is in very good shape but the second gear shift feels a little notchy. Now I know that in any manual transmission car second is going to be the first to go. My question is does Redline MTL help this issue. I have used it in BMW's in the past and it was like a syncro in a can. However my son has a BMW E46 M3 and it didn't help at all. Second question, BMW does not sell syncros anymore so I had to purchase a rebuilt gearbox for 4500 dollars. Of course my son and I swapped them and he is now much nicer to his shift lever. But the question now is Are the parts available and are there shops out there that can do the job (rebuild or just install a syncro)? Luckily my wife (she has only ever owned manuals) hasn't complained yet, but she could shift her old 915 gearbox in her 82 SC when I couldn't even get it in gear so maybe she has the touch. It does go right in but it feels notchy, not right to me.
Old May 6, 2015 | 07:48 PM
Jeller's Avatar
Jeller is infamous around these parts
My first to second gear was not good with my car either, bought it last year with 17K on it only. It was really bothering me and while I was getting an wheel alignment I Had the local dealer adjust the shift cables, per his recommendation, he said they have done it on quite a few cars with good success. It's not soo much of an adjustment but more so resetting them. They use the shifter alignment tool and reset the cables to the correct position, tech said one of mine was wayy out of wack as if someone had taken it apart and not assembled it correctly or it was not right from the start. In the end the shifting is much better and improved for sure. Still not as good as my audi or bmw was, but the adjustment did help alot.
Here is a link to some pics to get a better understanding of what was done on my car http://rennlist.com/forums/997-forum...placement.html
Edit: and in regards to fluid, every thread I read on here says OEM only, most do not have good reviews by changing to aftermarket.
Old May 7, 2015 | 04:57 AM
FlaHeel's Avatar
First gear has been an issue with the 911 since I can remember, the 2nd gear thing not so sure.
Old May 7, 2015 | 05:04 AM
porschelady's Avatar
porschelady is just really niceporschelady is just really niceporschelady is just really niceporschelady is just really niceporschelady is just really nice
Second is fine on wife's '08 C4 but 1st is sometimes difficult until transmission has warmed up. Much more noticeable when in sport mode.
Old May 7, 2015 | 07:16 AM
zegm's Avatar
The previous owner of the car had just purchased a brand new center console and a GT3 parking brake handle but had not installed them yet. Since I will be installing these items and the car has 66k miles it makes sense to purchase new shifter cables and install them and see if that helps. I think I will also try Red Line MTL in the transmission. Any one here try it yet? It works great on worn BMW syncros so I will give it a try.
Old May 7, 2015 | 07:39 AM
cool flash's Avatar
cool flash is infamous around these parts
i had exactly the same probs with my 2010 997.
Old May 7, 2015 | 07:43 AM
PTParks's Avatar
PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !PTParks Is a GOD !
I think I would instead try something like Motul instead of Red Line. Nothing against Red Line but Motul is definately a higher quality product.
Old May 7, 2015 | 09:50 AM
zegm's Avatar
I think that is a good idea. I did try Red Line in my son's M3 and it didn't make a difference like it did in the old BMWs. Now his car uses ATF in the manual box (like all BMWs for the last 15 years or so) but I purchased the Motul and it did seem to make a difference. Worst case the syncro is bad anyone had one changed and what was the cost?
Old May 7, 2015 | 09:57 AM
cool flash's Avatar
My indy quoted me 2800€ to repair the synchros. Parts are available since some time.
An exchange transmission from Porsche would have been 4800 plus install.
Regards,
CF
Old May 7, 2015 | 05:54 PM
PelicanParts.com's Avatar
PelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond repute
Might be able to read up on the clutch a bit more here in this Tech Article.
-Luccia
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Parts | DIY Help | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Old May 13, 2015 | 02:24 PM
carlosah's Avatar
carlosah is infamous around these parts
I have the same on my 2006 997.1. Have had the car a couple of years and it always seems to be worse in cold weather. I called the dealer to get an appointment for tranny fluid flush and the tech said it is normal on Porsches, no need to worry. Also had the best indy in town check it and said the same. I normally just take it very easy until the car warms up. All shifts are great once warm.
Old May 16, 2015 | 01:24 PM
Miami4me's Avatar
Miami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud ofMiami4me has much to be proud of
Originally Posted by PelicanParts.com
Might be able to read up on the clutch a bit more here in this Tech Article. -Luccia
Good article on changing a clutch, but it doesn't address shifting gears.
I have a SSK, which seems to compound the difficulty of shifting into first. As noted above, the best workaround seems to be to put the car into second, and then shift into first.
Old May 22, 2015 | 07:45 PM
zegm's Avatar
I received the new shift cables and after talking to Sun Coast Porsche I ordered the Mobile Synthetic Fluid used in the GT3. I have the center console off and the cables exposed. Tomorrow I will change them and the fluid and report back. Funny thing or maybe its a woman's touch but my wife has no trouble with second gear.
PV=nRT.
Sep 9, 2022 06:06 PM
cockneymike
Oct 22, 2015 06:00 PM
vogz
Sep 19, 2015 01:02 PM
nal991
Sep 11, 2015 09:05 AM
flewis763
Sep 10, 2015 01:08 PM
