Strange clutch problem
Old Oct 9, 2010 | 12:58 PM
Dadio's Avatar
Dadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond repute
Yesterday was out and about in the PCar and while changing gears and letting the clutch back out it felt as is it hung up about half way from full engagement. Engine was still a little cold so I was not on the gas very hard. It hung up for only a few seconds but while it was "stuck in mid return" I was still on the gas so clutch was half engaged resulting in burned clutch smell. Has anyone ever experienced this in a modern Porsche ? I have not in over 10 years of PCar ownership between my Boxster and now the current C4S and was more than a little perplexed while this was going on. Drove it this morning and all appeared normal.
Old Oct 9, 2010 | 03:49 PM
solidst8's Avatar
solidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud of
This happened to me before also, unfortunately, I can't explain this behavior either. The car still runs just fine to this day.
Old Oct 9, 2010 | 06:39 PM
mike87's Avatar
mike87 is infamous around these parts
maybe slave cylinder
Old Oct 10, 2010 | 11:37 AM
Dadio's Avatar
Is the slave cylinder prone to this type of problem ? Car was an end year close out but only from new since I've owned it a tad more than 2 years ( Cars 3 years old counting the time it spent sitting on the lot ). I'm a little over due on a brake fluid change (due every 2 years). Could that be the issue ? Is Porshce fluid more porne to moisture absorbtion than regular DOT stuff ? Slave doen't need anything else in the way of regular service I am aware of and with only 14K miles seems an odd issue to have on a relatively new vehicle. But then it's an odd issue for me altogether.
Old Oct 20, 2010 | 11:32 AM
wolfnards's Avatar
wolfnards has a spectacular aura aboutwolfnards has a spectacular aura about
yep - same here. i'm bringing it in to the dealer today to take a look. was it similar to this?
https://www.6speedonline.com/forums/997/84047-997-clutch-problem-other-issues.html
Old Oct 20, 2010 | 04:18 PM
Dadio's Avatar
My problem is simply the clutch hanging up about half way back. Clutch actually engages near the end of it's travel normally so the mid engagement hangup used up some of the clutch's life I'm affraid. While it's seems to engage later than when new could be my imagination. As of today all seems right with the clutch but will wait to see how you make out at the dealer before I take it in. Am hoping your visit will shed some light on my issue. As this was a one occurrence issue only I'm pretty sure it won't happen while anyone from the dealers service department is driving it.
Old Oct 20, 2010 | 07:36 PM
ryem3's Avatar
ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !
Mine made a clicking sound half way down the travel. Did it for a couple days until whatever was sticking broke. Clutch worked fine. Took it to the dealer and some kind of plastic part broke. Needed a new clutch slave cylinder. About $500, covered under warranty. So much for bullet proof Porsches. You may have the same issue.
Old Oct 21, 2010 | 07:03 AM
wolfnards's Avatar
thanks for the feedback. i will probably get an update sometime today and will keep you posted. ryem3 - sounds like the situation i'm in! glad it worked out under warranty
jaehoppa
Oct 22, 2015 09:17 PM
oo7
Sep 10, 2015 08:08 AM
GSP
Sep 9, 2015 05:31 AM
Saint Ari
Sep 4, 2015 03:30 PM
ECS Tuning - VW
Sep 3, 2015 09:43 AM
