997 battery replacement recommendation
Old Feb 27, 2014 | 01:38 AM
  #91
RSW's Avatar
RSW
RSW is infamous around these parts
Originally Posted by steve-o
As usual this forum proved invaluable. Went to start my (less than 1 week old - new to me) 911 last night and the dashboard lit up: PSM, ABS, etc… After a slight freak out and several google searches, I self diagnosed the battery was low. Ended up replacing with a Bosch 49-850B from Pep Boys (after a jump). In and out in only 15 minutes and only cost $135.00. I'm sure I could have gotten it cheaper elsewhere but not having to lift a finger has value in my life!
Thanks for all the continued great advice!
This battery from Pepboys is of Group 49 - not recommended H7.
Old Feb 28, 2014 | 01:17 PM
  #92
roelricardo's Avatar
roelricardo is infamous around these parts
Originally Posted by rebattery
Just remember those are made in Mexico
REbattery
I don´t see any problem that they are made in Mexico, do you?
Old Feb 28, 2014 | 03:02 PM
  #93
BigZ's Avatar
BigZ is infamous around these parts
That comment was over 3 years ago!
Old Jun 4, 2014 | 11:07 PM
  #94
lurchphil's Avatar
lurchphil is infamous around these parts
Ordered a Bosch Platinum AGM from Pep Boys, size H7/L7/94R from Pep Boys. The original Moll is only 2 and 1/2 years old but shows only 12.07 volts. The 2012 911S only had 4500 miles on it after more than 2 years. The Bosch net cost after two $25 online discounts and returning the old Moll, ($15 core), will be $154 delivered to my front door. Three year free replacement. Seemed like a heckuva deal to me.
Old Jun 5, 2014 | 06:19 AM
  #95
jhbrennan's Avatar
You can verify the date of your Moll by looking at the numbers stamped on the top of the negative terminal post - e.g., 25 and 08 would indicate battery was produced in the 25th week of 2008.
Old Jun 8, 2014 | 02:06 PM
  #96
AP1to911's Avatar
AP1to911 is just really niceAP1to911 is just really niceAP1to911 is just really niceAP1to911 is just really nice
get the best most expensive battery you can find.
I got mine at Pepboys it was the BOSCH brand and cost over $200
the dealership replaced my battery with an Interstate battery.. which was a pile of CRAP. my car cranked weak after only one month of use, and then it cranked like **** the rest of the time.
Never trust the dealership for your battery .
I do ALL my maintenance at the dealership, but from now I am going to be very wary of what parts they actually use on my car. I thought it would be some kind of Porsche approved battery.. NO. It was the cheapest thing you can find.
Old Jun 27, 2014 | 09:21 AM
  #97
cnachris's Avatar
cnachris is infamous around these parts
Just ordered the same BOSCH Platinum AGM battery H7/L4/94R for my '10 4S. $150 plus tax delivered to my door. Couldn't pass it up at that price for an AGM. The Moll is over four years old now. Even though it has been on the Ctek since I bought the car, before I bought it the car was in the dealer showroom for a while and had to be jumped each time I went to look at it. It is time to make a move......
Old Jun 27, 2014 | 11:49 AM
  #98
JohnAMG's Avatar
JohnAMG is infamous around these parts
I changed mine at the 5 year mark with the battery from Autozone. It was just under $200 and an easy DIY.
John
Old Jun 27, 2014 | 05:58 PM
  #99
oalvarez's Avatar
oalvarez is infamous around these parts
^ same here....Autozone Duralast H7 AGM....just replaced mine regardless if the original Moll was still ok. easy peasy, fit perfectly, felt less heavy as well.
Old Jun 27, 2014 | 07:16 PM
  #100
Robocop305's Avatar
Robocop305 is just really niceRobocop305 is just really niceRobocop305 is just really niceRobocop305 is just really nice
Walmart H7, great battery at a good price.
Old Jul 8, 2014 | 01:59 PM
  #101
Ynot's Avatar
Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !Ynot Is a GOD !
I assume it's this one? http://www.walmart.com/ip/EverStart-...ttery/20531542
It's $147 now, my 997 is slow to start in the morning, looks like I will have to buy one soon.
Old Jul 9, 2014 | 12:30 AM
  #102
jhbrennan's Avatar
That's the one. There are two vent outlets on the battery so don't lose the vent plug (for the unused vent outlet) - the plug is part of the positive terminal plastic cover - easy to overlook.
Old Jul 9, 2014 | 12:09 PM
  #103
Ynot's Avatar
Good to know, thanks!
Old Jul 11, 2014 | 07:01 AM
  #104
gonzo__007's Avatar
gonzo__007 is a jewel in the roughgonzo__007 is a jewel in the roughgonzo__007 is a jewel in the roughgonzo__007 is a jewel in the rough
just called my dealer about it.
if under warranty, buy the Porsche battery. otherwise they can void warranty if you have issues with stuff.
not under warranty answer was: as long as you put a battery with the same specs, you are good. 12 volt is 12 volt...
Old Jul 11, 2014 | 03:37 PM
  #105
Minok's Avatar
Minok has a spectacular aura aboutMinok has a spectacular aura about
And easy to not verify its there. The battery I had purchased had that bit already pulled off.
