Occassional Backfiring on Downshift
Old May 1, 2011 | 06:36 AM
amv8indc's Avatar
amv8indc has a spectacular aura aboutamv8indc has a spectacular aura about
I brought this up about 2 months ago, but I'm now certain my V8 Vantage is backfiring. Right after it happens you can actually smell gasoline. After reading up on other cars with a similar issue, I've found that this is basically due to an incomplete combustion cycle or remaining fuel in the chamber. Forgive me, I'm no mechanic. The first thing that was mentioned to do is to check the plugs. However I read that it takes 8 hours to replace the plugs in this car. Is this true? What do you recommend?
Another symptom that might be related is a strong hesitation or loss of power when I first give it gas.
Old May 2, 2011 | 09:47 PM
PeterW's Avatar
PeterW is infamous around these parts
Did you pull fuse 22?
Old May 3, 2011 | 06:02 AM
amv8indc's Avatar
Yes. However these are rather violently strong backfires vs what people have discussed as fun pops and gargles. Also, I have yet to hear others with a strong fuel smell. I did read about a service bulletin to replace a fuel cap, when you smell fuel often; I just don't know if this applies to my car.
Old May 3, 2011 | 06:31 AM
brumma's Avatar
brumma has a spectacular aura aboutbrumma has a spectacular aura about
There's a whole long list of VINs on the service bulletin. If you want to provide me the last 6 digits of yours I can look it up for you.
Old May 3, 2011 | 06:38 AM
amv8indc's Avatar
Thanks. D06745.
Old May 3, 2011 | 06:46 AM
brumma's Avatar
Yep. Your VIN is listed. Are you the first owner? If so, I assume you'd know if the service was already completed. If not, there should be a small sticker with #163 inside the driver side door jamb if the service was already done to the car.
Old May 3, 2011 | 06:49 AM
amv8indc's Avatar
I'm the 3rd owner (if you count the dealer between me and the original owner). The main recall was never taken care of, and neither was the brake shim SB; so I assume many things were over looked. I'll take a look in the door jamb this afternoon.
Thanks!
Ben
Old May 3, 2011 | 07:18 AM
brumma's Avatar
You're quite welcome! I have the same issue with mine. In fact, I think this was the only issue they resolved. Luckily, I haven't had too many issues so far, and the brakes only squeal on mine when the wheels are really dirty. Gives me a reason to keep 'em clean, right?
Old May 3, 2011 | 09:44 AM
amv8indc's Avatar
Yeah I also need to clean the wheels every 2nd or 3rd drive (city driving).
Here are pictures of my door jamb, I see no extra stickers. I edited out my VIN.
Old May 3, 2011 | 10:10 AM
brumma's Avatar
It should actually be on the front part of the door, like this:
Old May 3, 2011 | 10:14 AM
amv8indc's Avatar
Ha! I'll get back to you tomorrow on this. Thanks.
Old May 3, 2011 | 01:40 PM
vince_1972's Avatar
vince_1972 is just really nicevince_1972 is just really nicevince_1972 is just really nicevince_1972 is just really nice
you can check for service bulletins on mine? here's the number: C00355
Thank you!
Vincent
Old May 3, 2011 | 01:47 PM
brumma's Avatar
Thank you!
Vincent
Hi Vincent. Are you asking about the same issue? Your VIN is not listed on the service bulletin, but I'd double-check with your dealership to be sure.
Old May 4, 2011 | 12:02 PM
vince_1972's Avatar
Hi,
Thanks for your time
Best regard
Vincent
Old May 4, 2011 | 12:11 PM
brumma's Avatar
Hi,
Best regard
Vincent
De rien. Happy to help!
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
captain Greg
Sep 6, 2015 04:14 AM
