Since the dension Bluetooth adapter has poor audio quality have any of guys tried the iPod connector to Bluetooh audio adapter? It uses the power source from the ipod cable to power the Bluetooth adapter and it streams the music from any Bluetooth device through the same port. I have used this adapter for other iPod intended devices and works great, some of them I can change the music through the stereo and it transfers the command from the BT adapter to my android.
so maybe you guys can help. In the glove box it's got a pigtail plugged in somewhere and then it has a plug, it looks perhaps llike an ipod plug, any ideas as to what it is?
looking at the .pdf manual I downloaded from AM (it's for up to 2008 model year). They describe the usb port as being under the armrest. My armrest doesn't appear to raise, so i"m guessing the pigtail in the glovebox is for the ipod, I need to try it.
Chris
Chris, your 07MY didn't come with built in iPod integration or USB and also does not have a center console storage under the armrest. Any pigtail you see in the glovebox was installed by the PO. Did you not get the printed owner's manual for your model year included with your car? Let me know and I might be able to get you an electronic copy.
HI Karl,
Thanks, I did get the printed hard copy with the car, had thought the 08 manual would be the same, guess I better get that one out and read as a few differences here and there.
Got my dension installed everything sounds good but i still wanted Bluetooth, so i tried the Ipod bluetooth converter and didnt work out so well. I was able to install a High Quality bluetooth adapter from Harman Kardon, ebay link listed below. Extremely reliable and the sound quality is perfect. For power i used the Dension USB connection intended for flash drive audio,just connected a Mini usb cable, and for audio i used the aux port. You pair once and after that as soon as you turn on your car the bluetooth turns on and automatically connects to your phone. Perfect sound quality and definitely reliable.
Thanks again for posting this DIY. It was immensely helpful and I'm happy to say that I can now play my iPhone 6 plus music wirelessly and control it with the stock radio controls! To play wirelessly, I added the viseeo Tune2air adapter:
A couple of observations:
-When connected with the Tune2Air, it does not show song/artist details. It just shows Track 1, track 2, etc.
-Sometimes at startup, the stock radio searches for actual CD's and I can hear the CD player shuffle mechanically. Eventually, it connects to the iPod and plays the music. Are you guys experiencing this delay / bugginess as well?
Lastly, thank you to all the other contributors on this thread. I can also confirm that I connected the Dension with dip settings 2b (1,4,6 on) and connection/flow diagram 1C. What really helped me was to trace the path the "light" was going and that guided my wiring of the fiber optic cables.
Please let me know if you guys are experiencing the same delays/bugs I am with the "phantom" cd loading issue.
Congrats. I sent you a PM. However, I never had any phantom CD changer issues when I had that car. I wonder what's causing that? Have you made sure you have the most recent firmware for the Gateway?
Great recommendation. I'll try loading the latest firmware. Forgot to do so with all the excitement of being able to play my music
I hope that fixes it.
Update: Just loaded the latest firmware per Karl's recommendation and IT WORKED! No more empty (phantom) disc loading. The player just blinks and pauses when changing "discs" and going through the menu.
It's still a little buggy, but still way better than no ipod connection at all.
Thank you!
Reason: Update
It clearly recognizes my Ipod Classic 160GB but with the 2a DIP-switch settings is changes automatically to DISC 5 and into IU-mode but without any sounds. When I skip my track to DISC 5 track 3 it seems to go into Ipod GW-mode, displaying the song titles on the small Aston display and allowing me to control my Ipod thru the display; i.e. allowing me move thru the Ipod directory. Even the IPOD displays DENSION GW500 mode with a version number on it.
My disc 2 shows empty. As per Dension's instruction and mentioned in this thread previously the trick to get it working should be to change to DISC 6 and then select track 3. Anyway, I'm able to do this but other then displaying IPOD IU mode (what I want, controlling thru my Ipod) but still the sounds does not get thru. Even when selecting other 'tracks' on DISC 6.
I've tried even the DIP-switch settings of type 2A for Volvo but with similar results.
Any thoughts / advice? What am I doing wrong here?
After reading this thread I decided to take the plunge and buy the Dension unit. It's has been frustrating to say the least. I am able to get my android phone to play using the RCA jacks and it sounds nice but I did not have an iPod but I do have an iPad with a lot of music on it so it tried to use that to see how it worked. I couldn't make it work so I bought and iPod. And it has the new style connector so I bought the adapter. I can't make it play. So my first question is how to do an update because I can't get a display on the radio. And second will the newer iPod work? Since I can make it play the way it is I assume it's hooked up right. I tried different set ups per the instructions and what I've read here. Any ideas suggestions?
Thanks in advance
Thanks for the guidance. Will check the light path once more (although I'm sure I got it right) in combination with the DIP-switch settings and diagram 1C.
