Stuff I am working on
Old Apr 13, 2019 | 12:01 AM
  #301
DetomasoGTS74's Avatar
Old Apr 13, 2019 | 05:34 PM
  #302
era2076's Avatar
era2076 is infamous around these parts
Eric, can you post up a pic of the adapter they sent you.
x-clif
Old Apr 13, 2019 | 06:22 PM
  #303
x-clif
here is the adapter plate I had slotted to fit:
So my passenger seat is now stuck in place with a rounded hex bolt where it attaches to the adapter plate. They did not send me a second riser with a bolt for the bottom of the seatbelt, I missed it, and installed the seat and in the process rounded one of the bolts. Extremely disappointed as I don’t see a way to get the seat out.
Old Apr 13, 2019 | 10:47 PM
  #304
era2076's Avatar
Did you notice that the front and rear mounting holes in the seat are not in the same plane i.e the rear mounting holes are tapered in relative to the front. Measured across the seat the two front mounting holes are further apart than at the rear. The seat frame they sent does not compensate for this. I wondered why the rear bolts did not cinch down evenly against the frame at the rear. It all became very clear when we went to bolt it in.
Pretty sure you can purchase an easy out type of tool that will get that bolt out of there for you. We have several different types.
chr
Old Apr 13, 2019 | 10:52 PM
  #305
era2076's Avatar
something like this
Screw Extractor Set Screw Extractor Set
chr
Old Apr 13, 2019 | 11:34 PM
  #306
chr
I didn’t notice this but also didn’t have any issues with the rear mounting flat. I’m wondering if the difference may be that I am using the ultra low side mounts and different risers? I will check out the drivers seat I have yet to install as am waiting for the lower belt risers to be sent.
Old Apr 13, 2019 | 11:37 PM
  #307
something like this
Screw Extractor Set
chr
Appreciate it Cliff and I am aware of these. What I failed to mention was that with my ultra low side mounts the bolt in the picture above that is rounded is only 2.5” below the seat. There was not enough room to get my standard ratchet in there with the 5mm bit when I was installing the seat. I had to switch to a very long and low breaker bar to get it on (also how I rounded it).
I am very open to any ideas as I’m stuck.
Old Apr 13, 2019 | 11:55 PM
  #308
era2076's Avatar
The seat cannot slide enough to gain access?
chr
Old Apr 14, 2019 | 06:37 AM
  #309
TR-Spider's Avatar
5 Year Member
TR-Spider is infamous around these parts
I had good luck with using a Torx key in a runded Hex...Important is to beat it into the old Hex (which requires acess...)
Thomas
Old Apr 14, 2019 | 07:34 AM
  #310
chr
Correct. Seat is slid all the way back against the rear shelf and the bolt is covered. Would need the seat to go back an additional 3”+ to allow access.
Old Apr 14, 2019 | 08:36 AM
  #311
Thomas
Agreed! Best solution I was able to come up with yesterday was to use a long anti slip hex that is supposed to grip rounded bolts with a 5mm socket attached and an extension bar on the other need of the socket for leverage. This was the lowest possible solution.
Given the minimal distance between the top of the hex key and the seat I could barely tap it in with a low profile wrench. There’s no way to beat down a Torx or hex one size up.
Unfortunately after tapping in the Hex and pushing down with all of my might as I turned, it just spun freely in the bolt.
Old Apr 14, 2019 | 02:16 PM
  #312
TR-Spider's Avatar
5 Year Member
Can't you remove the seat including the subframe(s)?
It looks somewhat tight to reach the (outside hex) bolts.
Maybe a good idea to modify the sliders such that you can reach the bolts in the future (once you solved the rounded bolt issue).
Old Apr 14, 2019 | 04:18 PM
  #313
Unfortunately I cannot. The bolts that attach the adapter plate to the OEM mounting points are partially covered in front and completely covered in the rear.
Adjusting the front of the sliders would fix this moving forward but the rears would would need over an inch taken off...
I then looked to try and remove the seat from the side mounts so that I could drill out the bolt but one bolt on the side of the seat is blocked by the riser that the buckle is attached to.
Old Apr 14, 2019 | 04:46 PM
  #314
era2076's Avatar
Wow this is getting tough. The seat is in it's furthermost aft position?
chr
Old Apr 14, 2019 | 04:48 PM
  #315
era2076's Avatar
You cant't un-bolt the adapter plate from the chassis and lift the whole thing out?
