2007 V8V dash died while driving.
Old Sep 6, 2017 | 09:12 AM
Senatorblutarsky's Avatar
Senatorblutarsky is infamous around these partsSenatorblutarsky is infamous around these parts
I would recommend contacting Rich from Redpants. He has access to a lot of parts and may be able to expedite them. I have bought items from England and they have consistently been delayed at custom
Old Sep 11, 2017 | 11:22 PM
TJ851's Avatar
TJ851 is infamous around these parts
So I ordered and received the new CRM module. Install was relatively simple.
Seems to work like a charm now. Starts easy, dash panel works, roof works.
Thanks for all the great advice. You guys saved me a bunch of time and money.
Old Sep 26, 2019 | 09:10 AM
robkat's Avatar
robkat is infamous around these parts
I know this is an older thread, and others have the same CRM issue. Maybe you folks who have had this before can help me.
I have a 2009 Vantage Roadster. The previous owner said it had a bad CRM or needed a new battery and could not fix due to cost. I bought the car and got a new battery and new CRM from Scuderia. Install was fairly easy. Top still not operable. Dash still has lights on like it's a disco for Tire Pressure and Passenger Airbag.
I know the unit may need to be flashed, but is there ANYTHING in terms of fuses to check or other places to consider before I drive 90 miles to dealer for them to charge me for a flash, and it could have been a fuse the prior owner removed or something else?
Just covering bases here. Thanks
Old Sep 26, 2019 | 10:49 AM
zuman's Avatar
zuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud of
Try removing the new CRM and driving the car. If dash lights, etc., all function normally without the CRM connected, I believe that confirms that the CRM is the source of the problem and the new one needs to be flashed.
That was the case with my DB9.
-Mike
Old Oct 7, 2019 | 10:36 AM
robkat's Avatar
Next steps?
So with the old or the new CRM, the top still does not work. New battery as well. Switch does nothing... no motor sounds trying or pumps working. Top sits right where it is, closed.
My parking sensors have no sound, no lights on the button, pressing it does nothing either, zip.
Traction Control has no errors on the dash, but the button doesn't seem to do anything either, no lights. zip.
Possible a fuse somewhere that controls any and all together i could try and look for?
Old Oct 7, 2019 | 10:53 AM
Eric997's Avatar
Eric997 is infamous around these parts
Did you try taking out the CRM module all together to see if that fixed all the other issues (dash lights, etc) but the top? Based on others experience, that should be the case if it is a bad CRM. If that is the case, it sounds like you need to put in the new CRM module and take it to the dealer to get it flashed to get the top working. If that is NOT the case and there are still other issues without the CRM installed, you probably have to dig deeper which may mean taking it to a shop that can handle further troubleshooting.
Old Oct 8, 2019 | 06:44 AM
robkat's Avatar
My dash does not seem to have the typical problems related t the CRM, so that is what I am trying to solve. I'm thinking it's not a bad CRM module, since the car does the same thing with the new CRM. My dash lights never went out or went dark like most say. Mine shows errors which I now am assuming are just regular code errors I need to fix.
So if it's not the CRM, what else could it be preventing the top from opening? If you hear NO motor noise, I figure it cannot be a pump. I'm thinking something else electrical.
Old Oct 8, 2019 | 09:21 AM
Irish07@VelocityAP's Avatar
The only symptom your experiencing; is the top does not work, so you changed the CRM?
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
Old Oct 8, 2019 | 12:14 PM
robkat's Avatar
I was told by the previous owner the top did not operate, just stopped. He also noticed a check engine light, passenger airbag light on, so upon "internet searching" he thought it related to the CRM.
I bought the car knowing it had an issue with the top. I thought the same, I put a new battery in and replaced the CRM module. Nothing changed.
So obviously i'm thinking its something else and looking for help to what it could be. Fuse? Another electrical component? Motor?
Again, I have not flashed the new CRM, but my thought is, if the CRM was bad before, wouldnt the dash issues that everyone has be the same? Dash shutting off, going dead, etc? So i'm thinking I replaced the CRM for nothing.
Old Oct 9, 2019 | 10:47 AM
If the battery goes dead or door modules stop communicating with the CRM, top will not work until the CRM gets the programmed position of the windows. Meaning if the widow memory is wiped out, top will not open and will not give any errors. Another thing to note, if you purchased a CRM and it was calibrated at factory DB9/DBS/Vanquish..etc or used part from a DB9, the CRM will wait for the command of the 1/4 glass windows to lower before sending the command to the hydraulic pump. The CRM will detect an open circuit to the 1/4 glass windows being you don't have on Vantage, thus error'ing the top function. Vantage owners have had good luck with plug-n-play, but working at an Aston Martin dealer for 15 years has proven to me it 's not always the case.
The airbag light, is commonly the passenger seat weight sensors not calibrated OR back of seat has collided with the rear trim (were battery is located), this gives a false reading of the 4x weight sensors to trigger the airbag light. Correction is to calibrate the passenger seat and erase the SRS fault code.
First thing I would do before being a part swap mechanic. Buy a fault code scan tool that can communicate with all the modules. Do a scan and diagnose the faults that are stored. You don't need an $80,000 AMDS2 just for code reading. Companies like Autel, Foxwell..etc sell hand held devices for single user applications that work on all the Aston Martin Vantage modules..I'm sure if you search 6speed you will find a large percentage of AM owner shoot for the Foxwell unit and only pay for credit towards desired protocols.
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
Old Oct 10, 2019 | 09:22 AM
robkat's Avatar
I did the window reset, right after the new battery was installed, so that should be all set. I just figured if there are additional fuses that control the top or top functions, i'd try those. The manual seems to show 3 or 4 fuses I think in different locations. Just wasnt sure with anyone else's experience, if they knew how to diagnose this.
Yeah, I need a better scan tool, I also have a couple Porsche's in the garage and i'd like to get something decent that can handle all the cars and issues that may arise, without breaking the bank. Any recommendations there would be helpful too.
MrOz
Oct 14, 2024 06:21 PM
biggee
Feb 21, 2017 11:57 PM
SimonB
Apr 11, 2016 02:45 PM
k3nny
Bentley
Jun 4, 2013 10:16 AM
torresmd
Jul 5, 2009 10:36 AM
