Left blinker
Old Oct 8, 2019 | 06:30 PM
Thom Morrow's Avatar
5 Year Member
Thom Morrow is infamous around these parts
Left blinker
Problem #2 of ?? 07 V8V. Got Bulb Failure Left Turn Indicator. It is intermediate so I can’t see if anything is actually out. By the time I can get out for the fast blink, it’s gone. First is there a way to see speed when this error appears (message takes up screen)? Second any troubleshooting that comes to mind?
thanks
thom
Old Oct 8, 2019 | 11:05 PM
Eric997's Avatar
Eric997 is infamous around these parts
I've got the same problem and have not be able to determine if it is a really a light out or something else. There is a "Read" button on the right side above the A/C controls that will clear the error from the display.
Old Oct 9, 2019 | 09:27 AM
NotanM's Avatar
NotanM is infamous around these parts
Check the LED strip they can have an intermittent failure.
Old Oct 9, 2019 | 10:22 AM
5 Year Member
NotanM,
When you say, "Check the LED strip" are you referring to the front head light and a single LED not working?
Thanks in advace
Thom
Old Oct 9, 2019 | 10:52 AM
RolexDaytona1's Avatar
RolexDaytona1 has a spectacular aura aboutRolexDaytona1 has a spectacular aura aboutRolexDaytona1 has a spectacular aura about
Lots of posts on this..
This is an ongoing issue for us older V8Vs.. There is a small circuit board in the headlights that controls the LED strips... you can get a white light or yellow light or both failure. It starts intermittent... then full off. No way to get past the bulb failure notice.. just turn it off each time.
I presently have just the turn signal failure. No known replacement board on the market... people have had mixed results trouble shooting them. I bought a junk headlight on ebay and plan to salvage the board.
Taking out the entire headlight is lots of fun.. cracking it open... attempting repair.. and then reassembly... figure 5hrs first time.
Old Oct 9, 2019 | 11:11 AM
5 Year Member
That sounds amazingly fun... lol... If it is a single layer circuit board I am not too scared for soldering on components. Makes me miss my Cayman a little since taking out head light was like 45 seconds. I really appreciate the information.
Old Oct 9, 2019 | 11:26 AM
NotanM's Avatar
Originally Posted by Thom Morrow
NotanM,
Thanks in advace
Thom
Yes, the strip that runs along the inside of the headlamp housing. As the other guy said if you are handy you can open up and repair the board.
Old Oct 9, 2019 | 01:39 PM
Eric997's Avatar
Look at this post. It will give you a good idea of the issues most have faced and options to resolve. There are also some other posts that mention this problem as well as others can happen with a weak battery. So suggest you always keep that in the back of your mind when dealing with electrical issues on these cars. Won't always be the problem, but might be in some instances.
https://www.6speedonline.com/forums/...-signal-2.html
Old Oct 9, 2019 | 02:11 PM
5 Year Member
Wow that is great information. Eric997 thanks! I searched and never found that post, blaming on crappy searcher (me).
Old Oct 10, 2019 | 11:52 AM
I did the full in/out of the headlight and 'thought' I had the board fixed.. it died a week later... Next time I am in the mood... I can try my new ebay part. (haven't been that bored in quite a while)
As a general note I don't believe Aston EVER intended the owners to work on these cars. Wait till you change the battery! Great fun also.. Not 5hrs, but definitely not 5min.
It is all worth it however... these cars are very reliable for what they are... and great to own. No one would believe my 06 (with 80k miles) ... is a 14+yr old car. It just looks too damn good!
Old Oct 10, 2019 | 12:21 PM
5 Year Member
RolexDaytona1,
I totally agree on them not planning on us working on them. But I am cheap so, I will take a crack at most anything to keep from paying someone else to do work for me. WIth left blinker problem, I am contemplating digging down to the battery (watched video already) to see its age. Secretly hoping it is old and that is the problem. Not real hopeful but a guy can dream.
Thom
Old Oct 10, 2019 | 12:56 PM
RolexDaytona1,
Thom
I too try to DIY as much as I can... re-doing the door struts was as close to a ship in a bottle as I want to get. If you do buy a new battery... verify it hasn't been sitting on the shelf too long.. You can buy non OEM makes that are same spec outside the dealer. I bought one that died a month later because it had been sitting too long... and I had to do the battery change twice... July then Aug in FL. You may want to consider some of the smaller / lighter battery options ... check with RedPants.lol.
Have Fun!
lovingit
Aug 19, 2019 11:39 AM
gammaman
Cayenne 955/957
16
Dec 11, 2010 01:47 PM
CaymenSKid
Apr 18, 2010 02:21 PM
yalmutawa
Cayenne 955/957
Feb 28, 2010 11:19 AM
