DB11 tyres
Old Oct 16, 2018 | 03:49 PM
ducatirider's Avatar
ducatirider is infamous around these parts
DB11 tyres
Hi guys,
Time for a change of tyres on my DB11 V12.
Carried out a search on here, didn't yield any information.
Apart from the Bridgestones that were fitted from factory (which I have found to be quite poor in both the wet and dry and only last a few thousand miles), anyone fitted anything any other brand? any recommendations?
Any info/thoughts would be greatly appreciated.
With thanks.
Old Oct 17, 2018 | 06:03 AM
Phil57DBS's Avatar
5 Year Member
Phil57DBS is infamous around these parts
Hello
Only the best Michelin Pilot Sport 4S
http://www.tyrereviews.co.uk/Article...irst-Drive.htm
tests
http://www.tyrereviews.co.uk/Article...-Tyre-Test.htm
second choice with less noise :
Vredestein Ultrac Vorti R
Old Oct 17, 2018 | 10:12 AM
J doubleU's Avatar
Great resource for tires in the USA. All the specs and most reviews on current brands.
https://www.tirerack.com/tires/TireS...SortCode=60157
Old Oct 17, 2018 | 11:58 AM
Thanks chaps. Yes the Michelin is the obvious choice.
Wondering if anyone had any direct experience with their DB11 and tyre choice.
Old Oct 17, 2018 | 08:42 PM
SheriffDep's Avatar
SheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to all
Michelin is not the obvious choice? Continental extremesport contact are wonderful. I run them on my DB9 and grip is just as good as the PS4's. Tirerack and others did tests on the PS4 and the Conti's when they came out and the PS4 ONLY beat the Conti in the "turn-in" category. I dont drive mine at the limits and dont track it either. So "turn-in" didnt make any difference to me. Saved 200$ on the set, and love them. Several other members have gotten them also and like them alot. Just wanted to give you additional information so you can make an educated decision on what you want. They are great in the wet, and great in the dry and quiet. Perfect for me.
Old Oct 18, 2018 | 01:29 AM
Phil57DBS's Avatar
5 Year Member
Yes agree
but the only problem with Conti is they last very few kilometers
so in the end they are very expensive in the price vs kms report
Old Oct 18, 2018 | 05:36 PM
Gene G's Avatar
Gene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond repute
I put the Michelin’s on my V8Vantage when I got the BC Forged wheels. Couldn’t be more pleased. They are much quieter, look great and are lighter. I’m sure that they will wear better. When it is time to change on the DB11 will definitely go with the Michelin tires and probably a set of BC Forged wheels. Changing from the stock wheels and tires saved over 6lbs per corner on the Vantage.
Old Oct 18, 2018 | 06:28 PM
SheriffDep's Avatar
The testing has changed since i last looked 2 years ago. The PS4 is edging the Conti's out. However, treadwear rating on the Conti's is 340 while the PS4 is 300. Might be the difference that the testing is showing. The Conti's WILL last a bit longer due to harder compound used, albeit only slightly. The Conti is the Extremecontact Sport. the tests shown above is a different and older tire
I probably would go for the PS4 now myself, but for my size its about $400 difference between the two and that almost pays for HALF a new set. So would ponder that a bit. Not likely most of us would be able to tell a difference IMHO
Old Oct 19, 2018 | 01:05 AM
Phil57DBS's Avatar
5 Year Member
300 $ front
https://www.ebay.com/itm/255-40R20-M...ect+Ratio%3A40 Section+Width%3A255 Rim+Diameter%3A20&epid=685477467&hash=item442a1b6a 7e:g:ApYAAOSwBgpbvOQp
less than 210$ rear for PSS or make offer for 4S
https://www.ebay.com/itm/Michelin-Pilot-Super-Sport-295-35ZR20XL-105Y-K1-Ferrari/263660578961?fits=Aspect+Ratio%3A35|Section+Width% 3A295|Rim+Diameter%3A20&epid=1028079394&hash=item3 d63652891:g:kTkAAOSwdcZa7Mp4:rk:1f:0
https://www.ebay.com/itm/New-Micheli...temCondition=3
you could go too for Pilot Sport 4S front to split water under the rain and Michelin Pilot Super Sport rear for fine motor skills
good job to mix the two as this...
Old Oct 19, 2018 | 09:27 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
I have P Zero's on the Rapide which seem fine to me.
Old Oct 19, 2018 | 02:14 PM
user 589724024824's Avatar
user 589724024824 is infamous around these parts
I'm with SheriffDep. I put the Conti ECS tires on my DB9 this Spring and they have been outstanding. Much more compliant ride and way more grip vs the POS OEM Bridgestones. I ran a track day on them a couple weeks ago at Road America. 50 degrees (F) and rainy and the grip was still amazing with imperceptible wear afterwards (mostly due to conditions).
https://driveforbabies.smugmug.com/2...00/i-xwHGv7k/A
I'd recommend them to anyone who is also considering the PS4S. I saved over $300 going w/ the ECS and between the ride quality, wet grip and overall handling, I've never looked back. It may give up a little in mid-corner grip vs the PS4S, but last time I checked, I'm not an F1 driver.
007JB
Sep 28, 2017 04:24 PM
steve harris
Mar 22, 2006 11:13 PM
Bignick
Cayenne 955/957
Jan 20, 2006 07:34 PM
watt
Jun 2, 2004 10:12 AM
watt
Sep 26, 2003 08:26 PM
