V8VS outside temp reading 130+ degrees
Old Jan 11, 2019 | 09:12 PM
englishmatt's Avatar
englishmatt is infamous around these parts
Hi All,
Today, my cars outside temp display started to read very high; 136 degrees. It's actually 42 degrees outside.
I have no error messages, everything seems to run ok...just reads very hot outside when it it actually cold.
Any ideas?
Old Jan 11, 2019 | 10:26 PM
J doubleU's Avatar
Do a search of changing the ambient temperature sensor. Part is less than $50 thru various sites. It's a DIY if your handy.
Old Jan 11, 2019 | 11:06 PM
62Jeff's Avatar
62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !
Yep, BTDT
https://www.6speedonline.com/forums/aston-martin/270674-outdoor-temperature-sensor.html
Old Jan 12, 2019 | 03:35 AM
TR-Spider's Avatar
5 Year Member
TR-Spider is infamous around these parts
Originally Posted by englishmatt
Hi All,
That brought me to an interessting idea: would it be possible to use the display as indicator for the engine temperature, if a oil sensor with the same characteristics could be found...Hmmm...and then a hidden switch to change between ambient and oil temperature...
Edit: after reading the other thread, where its stated the the ambient sensor affects "other" things, maybe not such a brilliant idea, however, if the senor only affects the AC, it would not be such a big deal.
Old Jan 12, 2019 | 10:12 AM
Thank you, headed to the dealer to pick one up ($50.32c) and will replace this afternoon.
Gotta love active, knowledgeable forums.
Cheers.
Old Jan 12, 2019 | 04:10 PM
Ok... so that was about the easiest fix ever; filling the car with gas is slightly harder than replacing the ambient air temp sensor.
No tools required. Just remove the top two grill slats (pull hard and wiggle), disconnect the sensor, pull it out of the body....insert the new one and reconnect. All in all, under 10 mins....and if i did it again, 5 mins or less.
Turn on the ignition and the air temp now reads accurate.
Thank you all for attaching the link to "how to" thread.
Cheers,
Matt.
Old Jan 12, 2019 | 08:33 PM
J doubleU's Avatar
You may want to secure those grill slats after your fix. Glad you got sorted.
Old Jan 12, 2019 | 09:01 PM
I did indeed double check them after reinstall and they are as tight as they were before. No movement at all.
fingers crossed
'02996ttx50
Sep 13, 2018 11:26 PM
Long Islander
Jul 8, 2016 05:51 PM
alevine
Jun 13, 2007 04:39 PM
