Stereo issue
Old Jul 5, 2019 | 06:55 PM
Vantagelvr's Avatar
Vantagelvr is infamous around these partsVantagelvr is infamous around these parts
Stereo issue
2007 Vantage , premium audio.
with radio tuned to fave rock station , rear speakers fade in and out front speakers fade in and out volume is all over the map even though Im not touching it .
Tune to a talk only station , all ok .
Rock music station engine off , all ok .
Tried replacement bluetooth switcher thing in the passenger footwell fuse box , no change .
any suggestions that dont involve the use of C4 .
Im driving this car out to the Maritimes in a couple of weeks and need a fix .
Old Jul 6, 2019 | 06:08 AM
MRCW's Avatar
Maybe the auto volume compensation control?
Old Jul 6, 2019 | 09:30 PM
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
Try disconnecting the battery for a minute or two and see if that helps.
Old Jul 7, 2019 | 08:47 AM
Vantagelvr's Avatar
So I did some playing .
Played with settings adjusted speaker settings to all individual settings , surround fader etc etc etc . All ok . Sat in car engine running no volume issues . Disconnected battery for a couple of minutes and read manual . Yes it has the auto speed volume compensation but doesnt say if you can disable it ?
Reconnected battery restarted car and did window dip reset . Stereo all ok . Reverse car out of the shop and sure enough Im crawling in reverse and the volume is all over the place again , rear speakers up down side to side etc .
Electronics really P$@s me off .
Suggestions ?
Old Jul 7, 2019 | 09:21 AM
XJRS Owner's Avatar
Turn off the speed compensation in the menu.
Old Jul 7, 2019 | 09:37 AM
Vantagelvr's Avatar
If it told me how to in the book I would .
How do you access the speed compensation menu .
Old Jul 7, 2019 | 11:49 AM
MRCW's Avatar
as i recall, it is under each mode. need to get into the menu controls. You have to do it for each mode, (ipod, CD, Radio, Sirius, etc)
Old Jul 7, 2019 | 04:21 PM
J doubleU's Avatar
There is no "off" setting for AVC just LO/MED/HIGH. you can still see if low to high makes a difference though. Are you sure your new switch box was good? A faulty new part can happen. Although it's the front speakers that are affected I believe. So if your having all speakers faulting the I'd be looking at wiring and or connections. You do store your car during the season possible vermin squaters?
Old Jul 7, 2019 | 05:34 PM
Vantagelvr's Avatar
Ok so I figured out how to get into the audio menus etc . Like JdoubleU says you cant turn off the speed compensation setting . It was set at medium . I tried low and that didnt work . So I did a factory default setting to reset everything. Reprogrammed everything the way I wanted it and set the speed compensation at high . Went for a quick spin and it seems all ok .
Time will tell tomorrow I have a three hour drive to La Circuit Mont Tremblant to the Jim Russell Race school for my single seater track day ��������.
I get to drive an real single seater race car .
997.1s
Apr 17, 2016 07:49 PM
Blue Chip
May 19, 2015 09:09 AM
Hella-Buggin'
May 14, 2010 12:17 PM
jaymoney
Jul 7, 2009 12:00 AM
mambodave
Sep 14, 2007 10:01 AM
