VAP Spring DIY/Spacers
Hey 6speed, I am looking to lower a 2010 V8 Vantage I just picked up for my dad and add to spacers. There seems to be a ton of info that is quite old on which spacers to use but many websites do not carry them anymore. Can someone point me to which spacers to buy as well as where I can find a DIY for the VAP lowering springs?
Thank you both, I search for that video for a month without finding it. I really appreciate you pointing it out.
I was hoping to not need to press the old studs out, is that the only way?
If you go any larger than 11mm you will most likely have to modify the existing studs.
H&R makes 11mm spacers which come with special lugnuts with more threads. If you go with this approach you don't need to modify the existing studs. I have the VAP springs plus 11mm H&R spacers on all 4 corners.
I got my set from Wheel Enhancement. They can also get blackened lug nuts.
https://www.wheelenhancement.com
Just FYI, if you go with the 23mm you may have to cut the factory studs. In most stock wheels, the pockets are not deep enough and the factory studs wont fit. On the v8’s i believe the oem sport pack wheels are the only ones with pockets deep enough. I know for a fact that the standard vantage s wheels wont work, i found out the hard way.
